Question about Fuji FinePix F601 Zoom Digital Camera
Shadow in Photos
I have a shadow appearing in any shots of bright skies, etc in the example attached. It looks like a hair or something, but the outside of the lens is clean and the camera (Fuji Finepix F601 Zoom) is sealed. Has anyone experienced this before, and hopefully found a solution? Thanks
    Sergeant:
  • 255 Answers
Something on the sensor. Digicams aren't sealed and crud can get in. It's not as easy to get off as that on a dslr but Fuji can do it. Perhpas a talented and knowledgeable (on Fujis) repairman can as well.
Posted on Sep 12, 2005
    Sergeant:
  • 255 Answers
If that were a digital SLR I'd say you have something on the image sensor like a piece of lint, making it all the worse in a camera such as yours if that is the case. Does it show up in the same place on the sensor in every shot? If so a trip to Fuji to clean it off is probably what you're looking at. "Sealed" is fine if nothing is in there in the first place, but this was made by human beings, so things happen.
My Nikon D40 has developed a shadow in photos, not associated with lens. Please advise.
Is this shadow more like a spot that you can see clearly in areas of the picture like the sky? If so, this could be dust on the sensor. This is easy enough to remedy. Just Google the words "how to clean a DSLR sensor" and you will find sites that explain in detail with pictures the entire procedure. You will also find the materials needed and where to find them.
Sep 22, 2010 | Nikon D40x Digital Camera
I am seeing shadow pictures and red colors on my screen
If it looks like the attached photos it is a convergence problem and typical.
I can tell you what is needed to repair this if you are a do it yourself person.
Let me know if the photos look ANYTHING like your problem.
STEVE--SD TECH
Jun 10, 2010 | Hitachi 53UDX10B 53" Rear Projection...
48" with blue shadow on right half of screen
I am going to post a photos here for you--if your problem looks something like the photos I can give you START TO FINISH STEP BY STEP INSTRUCTIONS FOR THE REPAIR AND TELL you the best place to get the photos.
I think you have a CONVERGENCE problem but you will know after you look at the photos.
Let me know and I will be happy to post the instructions etc here for you and if possible tell you what you need to fix the set.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My Nikon N65 flash leaves a dark spot on all my photos
tlguthrie,
I love that camera. There are several possiblities, If you are using the pop up built-in flash with a telephoto lens or a lens hood you'll get a shadow in your photos ususally at the bottom of landscape oriented shots. If you are using a flash unit attached it may have something interfering with the strobe possibly or it is turned. We have the same camera and have had the shadow issue in the past. The pop up just won't work if something is wrong with the "bulb" the only other thing is that is isn't going all the way up, check that also.
randy32osgi
Jan 13, 2009 | Nikon N65 35mm SLR Camera
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Spot/shadow on monitor and pictures
Does it appear on the photos if you look at them on a computer or print them out, and does the spot remain when you're using the menu?
If it's there all the time (on menus as well) it would suggest part of the display is starting to fail.
Also, have you done the shutter hold-up so you can check behind the mirror just in case it's something on the sensor (assuming it's not just the LCD that's failing)?
Jan 02, 2008 | Nikon D40x Digital Camera
Blue shadow RCA p52771at
hi yeh it does sound right sorry do know anybody arround there... good luck
Feb 22, 2006 | RCA P52771AT 52" Rear Projection...
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Fuji FinePix F601 Zoom Digital Camera Logo
37 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
