Question about Sony BDP-S300 Blu-Ray Disc Player
Incompatable video signal message received.. ck out put cable
I dont have a manual. Any help?
  • Sony Master
  • 1,689 Answers
Did you bring the unit from another country with a different system?
If the unit worked before and it is not now, it should be checked out by a service shop where they have the tools and instrumentation to diagnose the fault.
Jerry G.
Posted on Sep 01, 2008
Hi, I have a Lenovo Z470 laptop and I want to connect it to my Philips Smart TV (40PFL5507H/12), I thought it will be straight forward connection, but the TV is showing no video signal receive, please
HDMI is the best method as VGA is low density video. You may have to set up the laptop to send data output to the HDMI/VGA port (Out to the TV). Your manual should spell out the procedures to change from Computer Internal Video to Video OUT.
Feb 08, 2018 | Lenovo IdeaPad Y510 Notebook
I dont know how to connect it to my tv!?!?!?!
Look in the manual.
The only vital connection is a simple composite cable or whatever your unidentified TV requires. The TV has a manual, too, somewhere.
I personally would not bother routing any video from external sources through the receiver as no signal will benefit from the extra cables and connections.
Aug 13, 2011 | Onkyo HTR500 Receiver
When I connect my Laptop to my HD TV using a HDMI cable, I get a message saying "incompatible video signal has been received.Check the output video settings." Any ideas?
A TV will only display certain resolutions from a pc I would try to lower your pc resolution to its lowest setting and see if that clears of the problem if it does then slowly increase the setting until you get that message again then dial back one setting and that will be the highest resolution it will take. Also be aware that if you are trying to play certain games on your pc while displaying on your HDTV that signal will not always render.
Apr 10, 2011 | Computers & Internet
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
Apr 08, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
Passing HDMI signal fro cable box to yamaha RXV463 to Samsung HDT
It sounds like a resolution problem to me. Try adjusting the video settings on your set. It may need you to switch modes as some TV's do this (Why I dont know). I have found that even sometimes its the cable service to blame.
Mar 22, 2009 | Yamaha RX-V463 Receiver
Cant record from security camera on rd2780
There are several possible reasons for it:
1. Check for a loose or false contact in the connector jack of the media player. Unplug and plug it again, or rotate it.
2. The Video/Audio cable is defective. Such media players when were brand new, there were 2 sets of cables in the box. If you have the 2nd one, try it.
3. Check the video output of your security camera with other device (a TV set, a VCR, etc).
4. Confirm that both the security camera and the RCA media player are in NTSC system format.
5. Check the performance of your RCA media player video/audio input with other video source (VCR, satellite receiver, cable box receiver, TV set, etc). There are sometimes that there is an incompatibility between devices because of diffrences in the synchronization signals or voltage levels of the video signal.
Best regards,
Feb 25, 2009 | Toshiba Netcam Software for Record Up To...
Can't Get A Radio Signal When I Connect A Cox Cable
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Sony BDP-S300 Blu-Ray Disc Player Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
