Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Posted on Sep 01, 2008
Burning plastic smell, colours way off, picture way off & skewed
My tv just went weird. There is a blue & red rim around the picture (may also be another colour, it's just hard to tell. There was a clicking noise and then the picture went strange. Then the burning smell. Thoughts?
A
Anonymous
Thats funny!My TV is doing the same thing,but now I hjave no picture just sound!
My Lg colour tv is getting these weird red and blue shadows that makes the picture looks like it's in 3d can I fix this?
thats called ghosting its usually down to your tv ariel try putting your ariel on a mast for a better clear reception.
Hi, LG 42" today started
you need to take rear cover off to inspect whats happened ..u will see or smell what gone wrong if done asap... UNPLUG FIRST ....
1helpful
There is a green glow around everything in the picture of my Mitsubishi WT-46809 46 in. rear projection TV. I can fix the red and blue tones but not the green glow around everything. What might be the...
I am going to post some photos here for you. If you went into the customer menu and tried to adjust convergence and red and blue would move but green is skewed--you have a convergence problem.
Look at the photos and tell me if any look ANYTHING like your trouble. If you have a convergence problem with this model I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS I CAN GIVE YOU.
If this helped you rate this solution as I do this here for free.
SD TECH
Photos:
e93a4cd.jpg OR?
4helpful
Picture suddenly appeared out of focus, with different colors not lined up as they should be. A horizontal line shows up as two parallel ones, one red and one blue. This all happened to the accompaniment...
This is a model first sold in 2000---if convergence is skewed and will not align in the customer menu:
It uses two of the STK-392-110 convergence chips--I suspect if you smelled something that when the chips went bad one or more of the protection resistors around them toasted--burned to protect the set from the short.
Both chips and any bad resistors need to be located and replaced--parts cost On Ebay would be less than 30 dollars--I can tell you the best seller there.
If you or someone you know can do the repair you can save the set and a lot of money--Most shops are going to charge at least 300 for this kind of repair.
It should be able to be fixed right in your home--I know as I have repaired hundreds of sets with this problem.
If you need help or advice--let me know--I am here to help.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
2helpful
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Samsung Rear Projection SP43W6HFX- Smoke + Blurred Vision
Convergence IC's are busted.....google it. You'll find loads of solutions!
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
