Question about Brother Office Equipment & Supplies
Mfc-7420 ,when sending faxes puts a black line down centre of page
  • 1 more comment
  • Steve Hunt Sep 01, 2008
    Sorry, I need to expand on the problem. When sending using the ADF, the person receiving the fax gets a black line down the centre of the page.
    I added more info to problem
    Spot on solution. A tiny bit of white out ink was the culprit. Thanks very much.
  • 928 Answers
See if there is a part of the roller that makes a crease on teh paper The black line means that sensor on your end sees a mark on the paper and interprets that as a message or a charachter hence turns it into a line
Posted on Sep 01, 2008
    Master:
  • 638 Answers
Some dust on your scanner .the above solution sent by techexpert12 is proper aswhat your scanner contains that will be copied and that only will be sended.then let you send directly or copy from your machine and then sent.the above solution is perfect.
thanks.
  • hemant somaiya
    hemant somaiya Sep 01, 2008
    just needed the scanner cleaning.thats it.its very very very very simple.
    Master:
  • 521 Answers
The scanner glass which reads the page is dusty.or any hair like material is stuck on that.just open the scanner and clean the glass.
pls do rate the solution
thanks.
regards.
fixya expert team
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
When i am faxing do i put the paper up or down on this thing brother mfc-7420
Either lift the lid lay the paper in print side down, or put it into the document feeder print side up. In either case the top edge of the page should be at your left to appear right-side up at the receiving, but that's a minor point.
Sep 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Jun 14, 2009 | Brother MFC-7420 Printer
Have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
I can't sent fax out
hello ! click on menu scroll to fax click menu set scroll down to easy receiveclick menue set the fax should receive now providing you have dial tone on ythe line check with phone plugged in good luck brother sr tech
Dec 09, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
147 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
