Question about Cameras
My Casio X10 lens was
My Casio EX S10 lens was blocked when the camera was turned on and is now recessed in the camera and does not zoom out. Can this be fixed? If so, how can I dissasemble the camera to get at it?
  • 5 more comments
  • bobcampbell Sep 01, 2008
    Please provide information on how to repair the problem - taking it to a service center not the kind of advice I expected when I paid for this service.
    Your advice to remove then restore the battery and memory card did not help. This is apparently a mechanical problem in which the zoom lens is off the track and I believe I'll need to open the case to fix the problem. Instructions on how to do that would be appreciated.
    Get what replaced - the camera or the gear? And where would I take it for repair?
    The first response to the problem said it was a minor problem and should be taken in for repair - the latest response says the problem cannot be repaired - this seems like a contradiction to me. So far none of the responses have been particularly helpful and I am still waiting for a response to my last comment...
    Please tell me how to disassemble the camera and repair the problem.
    What do you mean by "take care of plastic locks internally" ?
    Can anyone give me more specific procedures to effect a repair? If the only solution that can be offered is to bring it into a service center I certainly don't need FixYa!
    President:
  • 1,952 Answers
Can cause inadvertant power up w/lens blocked. ... sensor of 7.2 megapixels makes it possible to get good enlargements up to 8 x 10, or even larger.
Posted on Sep 01, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 01, 2008
    While looking for lenses to buy for a digital
    camera, I've realized that there are many things about lenses that I
    didn't know about and are important in determining the overall
    performance of a particular lens.
  • 2,071 Answers
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Casio repair shop and Casio Digital Cameras should fix it for free.
If your camera is out of warranty, or if Casio refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Casio Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Casio Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great sample guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help;
Regards,
VOTIT
    Sergeant:
  • 241 Answers
Hi i had my camera do the same thing(fuji)
>Ist make sure to close the lens cover and turn the camera back on
>2nd use hold down the shutter button and open the lens cover
>keep holding down the button and now toggle the camera mode to the other selections like play. Then back let go of the button
  • Jayson Brollini
    Jayson Brollini Sep 01, 2008
    exilim.casio.com/resource/pdf/manuals/EX-S10.pdf
    Here is your manual i been lookin at it to trouble shoot it
  • Jayson Brollini
    Ok if you are still with us in the manual there is only one subject in the trouble shooting( PG156) but that is a obstruction regardless
    the only other thing is (pg132) reset back to default I also looked for a factor RESET but i did not see any. You may ned to take a closer look for yourself
    Thank You and please Post for help
    Rate the Advise from FixYa ExpertKindofcheap
    Master:
  • 763 Answers
In that case you might need a service technician who can help you open the device and fix some difficulties. it may cause a lot of problem if you attempt to fix it on your own.
cheers
CHARCOIS
    Master:
  • 638 Answers
Open all the screws with proper screw driver it will disassemble.
and take care of the plastic locks.internally.
thanks,
    President:
  • 1,263 Answers
Chances are you stripped the little gear inside. your best bet is to get it replced either warrenty or buy a new one. it cannot be repaired.
  • Ronald Mueller
    Ronald Mueller Sep 01, 2008
    as 9i stated before the gear inside the slides the lens is stripped you can not repair this. and chances are if you took it to a repair shop they would not have the part. i would be remiss in telleng you that there is an easy fix to this it is my suggestiojn that either you have it replaced under warrenty if it still is or buy a new one. trying to repair it yourself will only add to the problem. I know this is not what you expexted or wanted to hear but it is the right answer to your question. good luck.
    Genius:
  • 3,422 Answers
HI,
Well you can first try reseting it by removing the batteries and mem.card for 20min and then insert them back and turn it on.Let me know the result so that i can provide you further help.
  • 8 more comments
  • Priya darshan Sep 01, 2008
    Try compressed air.turn off the camera blow air between the lens turret
    and the camera body. It should remove all dust and sand. Turn the
    camera on an let me know the result.
    lens.Turn off the camera. Place it on the back with the lens facing up
    If
    Simply
    If the lens
    you can once try switching over to 2500 mAh Nickel Metal Hydride
    rechargeable batteries. you will see a difference.Digital cameras with
    zoom lens need more power than what can be supplied by ordinary
    batteries..
    OK i will need your email id to send you the procedure.There are many pics.
    i will need your email id to let you knw how to disassemble the camera and repair the problem with many pics.
    Can you please give me your email id??
    I've been asking you for your email id.Let me know so that i can give you the pics on how to repair it.
    Master:
  • 521 Answers
Take it to the service center.for more safety and perfection.
as it will not cost u too much for this very minor problem.
pls do rate the solution
thanks.
regards.
fixya expert team
  • tech expert12 Sep 01, 2008
    the gears inside the camera unit are to be serviced and the lens has to be realligned.it will not cost u more then a service charge to get it done.as if u with out the technical knowledge try to do and if the lens get cracked.as it is made up of very very thin glass.it will cost you more to repair it.still open the screws from the bach and top of the body.also see for the hidden screws behind the stickers.to make it easily opened.
My casio EX-S10 lens stuck out and wont turn on even with battery recharged
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
Casio exilim EX-S10 wont turn on and lens stuck out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here is a video summary of the steps:
Lens stuck
The slide motor start malfunction, You have to replace complete lens block assembly.
Thanks for using fixya.
Jun 16, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Taking photos with casio ex-s10 goes all white
It don't work shutter. You need in repair lens unit.
May 16, 2009 | Casio Exilim EX-S500 Digital Camera
Casio exilim ex-z40 camera lens will not close
Looks like the servo for the lens assembly is not functioning.Try pushing down the lens gently until is completly recessed and power the camera on after that.
Mar 23, 2009 | Casio Exilim EX-Z40 Digital Camera
"Lens Error" on Exilim Casio 8.1 mega pixels EX-z9
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 22, 2008 | Casio Exilim Zoom EX-Z80 Digital Camera
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Casio EX-600 makes clicking noises when the lens comesout.
Lens error. send into casio repairs and they will fix it for you.
Sep 09, 2007 | Casio Exilim EX-S600 Digital Camera
Casio EXILIM ZOOM EX-Z850 Zoom button doesnt work
You have to send it in to repairs. You're lucky that the lens even still comes out.
Apr 14, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Cameras Logo
374 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
