Question about HP Jornada 545 Pocket PC
No valid Windows Ce application on Jornada 545
Hi, I am using an OB500 running XP and activesync 3.5. When connecting a 565 to this portable thru an USB cradle and downloading apps, everything is OK, and apps are running fine. When doing the same thing with a 545 I receive the "No valid windows CE app" message. Any idea?
    Master:
  • 450 Answers
I use an Omnibook 500 with a Jornada 545 as you describe without problems. The most likely cause is the difference in processors. The first version of Pocket PC was supported on three different CPU architectures. The Jornada 545 uses an SH3 processor. Applications designed for the 565 will not run on the 545. You will need to find applications designed for the SH3 processor.
Posted on Sep 12, 2005
Having a hard time installing USB sync cable from hp jornada 540 to win xp pro sp3 hp desktop.......already installed ms activesync!!!!!!!!! hp win xp pro sp3 desktop says failed to connect to the...
If you do a new, clean install of XP in 2018, one would be missing hundreds of updates from Microsoft that would be very hard if not impossible to get. Some of those updates might apply to software that you want to use in conjunction with Windows XP. And if it is an older PC, you might not be able to find driver support for the particular make/model, and XP might not have the drivers you need. How many times have you heard someone say, "I just reinstalled XP, but now I am missing drivers?"
This could be part of your trouble, because even if your XP updated all the way up to April 2014, you could still be missing HP updates provided by HP/Microsoft through Windows Update.
Since Microsoft has not supported XP since April 2014, I would recommend not using it anymore in 2018.
Jan 29, 2018 | HP Jornada 540 Pocket PC
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
NEC MobilePro 900c softeare
maybe is because processor ou version of windows ce
Aug 22, 2007 | NEC MobilePro 900c Pocket PC
Jornada 565 - Downloading software - format
Hi, MIPS, SH3, and StrongARM are types of processors used in handheld PCs. Some software requires a specific processor to run. For instance, Microsoft Pocket PC 2002 requires a StrongARM processor. The Jornada 565 has a 206MHz StrongARM processor.
Sep 12, 2005 | HP Jornada 565 Pocket PC
Jornada 565 no longer being seen by ActiveSync?
Occasionally under XP Pro, my 564 won't be recognized when I put it on the cradle to sync. I just take it off the cradle and try again. My understanding is the XP loads an HP driver when the Jornada is detected as connected by USB, if that driver doesn't load succesfully, then XP won't recognize the Jornada.
Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
Sep 12, 2005 | HP Jornada 680 Pocket PC
Jornada 525 and Windows Media Player 9
Only a hint. Did you check the small print via the downloads for Pocket PC on the Microsoft web pages? If you download from the regular OS pages they don't mention that certain Pocket PC generations are not supported. I noticed this but only on Media Player downloads fom the pocket PC pages but it takes time to find this more detailed info. http://www.microsoft.com/windowsmobile/resources/downloads/pocketpc/defau lt.mspx
Sep 12, 2005 | HP Jornada 525 Pocket PC
Deleted Items Sync
did u empty ur deleted items folder in outlook if u did to stop it from syncing the e-mails open up active sync and go to tools options and then uncheck the e-mail
HP Jornada 545 Pocket PC Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
