The "U12" is due to the magnet that is attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. Either the magnet has come off or it is not aligned properly.
I'll be here if you need me.
so how do i fix the problem? do i take the green lid off and locate the magnet? because prior to the problem, i did find a bar of magnet in the laundry pile.
Thks Richard for the sharing info I had fixed up the broken lid with the hot melt glue. Now it backs to normal. Thks again.
How did melted glue works
Can i know where should the magnet at? Panasonic 14kg inverter
I magnet is good. Copper conducter is still look new. Then its Door Safety switch. I buy the spare part from Shopee and Fix it myself. Because of PANASONIC wants me to Pre-order it and wait for 3-4weeks.
For those who interested for the Link:https://invol.co/cllrp3
Panasonic NA-F70B2. The erro code U12 when start spin with stop moving. How ?
The error code U12 shows in my washing machine ( Panasonic NA-F70GS) because the lid is broken (the part no of lid unit is AXW001G6TP5J and cost around RM 64.00 in Panasonic Malaysia Sdn Bhd (Tel: 03-55437600) or you can also get it in Tong Kong (SS3 or SS2 - Tel: 03-78755946).
Hi, my washing machine is a panasonic NA-F70S7 and had error code U12, upon checking the code it should be the lid is closed. i've already closed the lod properly and its still had an error. what other troubleshooting for that code. and where can i can i find that magnet? thanks in advance
Its a switch. Clean the contact. Should be ok
where is spesific location of that switch?
1. Remove the lid.(turn off power 1st)
2. Remove the inlet water hose
3. Remove the top cover
4. U can see the sensor next to water pump. The sensor connect to the small rod on the lid hinge
5. Check and service the copper plate inside the sensor assembly
Error u12 and stop motor
Http://www.manualzone.com/service-manuals/Panasonic_NA-F70GS_NAF70GS/users-owners-manuals/ReWrite-SPFM-LNG1.Dyn.M84825337KYWRDS_Panasonic_NA-F70GS_NAF70GS_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
Above is a link for a service manual.
U12 is a heating element or drive, electronic fault, it also maybe the thermistor or thermostat itself, however without examining the unit it is hard to tell?
If you wish to DIY, then one must obtain and use the service manual to troubleshoot and isolate the problem with a view to repair. use the site below to assist as well.
http://www.acmehowto.com/howto/appliance/washer/washer.php
Else one should contact a local or head office from Panasonic, and ask for a referral to an authorised service center, when in touch here organise a service call and when they arrive then ask ONLY for a "Quote" for the proposed repairs. When then appraised of the prospective costings, then one can make up ones mind as to what to do, repair or replace?
H01
Pressure sensor or level switch detected as out of range
Thanks: Let me try this option and get back to you
Thanks. The problem was the magnet which had come out of the lid. When it was fixed. the machine works like a charm
may i know, where is the magnet
Is the error code samefor any panasonic models
I try to direct switch but same u12
u12
I am using Panasonic NA-F90B2, may I know the position of the magnet ?
I am using Panasonic NA- F90B2, May I know where is the position of the magnet ? Anybody can help?
