Question about Palm Treo 650 Handheld
Calendar Not Syncing
I am having a problem getting my calendar to sync with my 650. I am using outlook 2003 and everything else works fine. When I go into my palm desktop and select "Hot Sync", then "Custom" it shows the calendar as "do nothing". I then make changes to set up sync, set outlook calendar as the default, and close out. Once I sync, it defaults the desktop back to "do nothing" and my calendar entries never reach the 650. Any ideas or help? Calendar is much needed.
    Master:
  • 473 Answers
Goto kb.palmone.com and look up Solution ID: 31167 'OLERR: (number)' errors in HotSync Log that should help you out.
Posted on Sep 12, 2005
    Master:
  • 473 Answers
The Exchange ActiveSync (EAS) feature of VersaMail enables you to connect to your Outlook/Exchange account for both email and Calendar. You cannot run the Calendar conduit and also use EAS. It is one or the other - this is to prevent duplicates. I think that is why your Calendar conduit is disabled from the handheld side. I believe you could re-enable to Calendar synchronization by removing the EAS account in VersaMail.
    Master:
  • 473 Answers
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
Sync calendar to microsoft exchange server
Update your Versamail version to 3.5.4
Also, make sure that sync calendar and contacts is checked in the settings on your Treo.
Good Luck!
May 21, 2009 | Palm Treo 650 Smartphone
Double entries in Palm and Outlook
The closest I have come has been from a firmware update for the Palm phone. After the update, the phone saw my original contact list and created a second contact list from what was present in the Palm calendar.
If you have changed firmware and this issue started happening, you'll need to delete the duplicates in Outlook or it will continue to try and update/save them. Also, this is most likely why your sync sessions are taking more time...the phone is trying to read the different entries already present in outlook, and it is taking time to default when it cannot open the entries. Multiply that time by 4 or 5 times per entry and you have a very long sync session.
Hope this works for you!
Apr 02, 2008 | Palm Treo 650 Handheld
Sync iphone to outlook
Only way i could get any sync was first strangling the cat,wrapping its limp body round my neck,then getting two pieces of celery of equal length.Soaking these overnight in a mixture of lemon juice and urine.Drink the juice at 2 minutes past twelve on a full moon,insert the celery where the sun dont shine and whilst hopping on one footand circling the p.c with the iphone balancing on my forehead.First few times no joy then bingo synched right off.
hope this helps
Jun 30, 2007 | Apple iPhone Smartphone
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Sep 12, 2005 | Palm Treo 650 Handheld
Outlook 2000 Calendar won't synch to Treo 650
goto kb.palmone.com and search by solution id: 31167 for olerr! That is about 1 1/2 hr of troubleshooting to do so: Good luck!
Calendar OLERR:04-0026 with GoldMine Link for Outlook
Please try companionlink, much better than the built in Outlook Sync.
If you like it please let us know and we can provide the licences for you
sales@asap-crm.com
ASAP CRM Consultancy
www.asap-group.com
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Treo 650 calendar not syncing back to Exchange
I am experiencing the exact same issue. Are you saying that this only occurs with one of your 650s? If so then maybe it is a hardware issue.
Treo 650 (cingular) and Outlook calendar
Its the substandard conduits that come with the 650. Hi - my issues were different than yours,but similar in that bottom line, my calendar data wasn't syncing correctly with Outlook. I've been dealing with this problem for the past 4 weeks. Sprint's technical support was useless, as was palmone. For 5 years, I have successfully synced my Palm Smart phone to palm desktop at home, and outlook at work - (4 different phones, 4 different companies). It dawned on me - for the past 4 palm devices, I was provided Chapura conduits... The 650 didn't come with them... GUESS WHAT. I bought Chapura Professional XT and all the issues I was having (they were too copious and too weird to go into here) were solved, in one measly synchronization. ALL of them. Don't wast ANY more of your time... Navigate over to Chapura's website and get one of the conduit programs -= trust me... You'll be glad you did.
Sep 11, 2005 | Palm Treo 650 Handheld
Treo 650 from Cingular is not hotsyncing with Outlook Calendar?
Have you setup an EAS account in VersaMail? The VersaMail application on your Treo 650 supports Exchange ActiveSync, which allows synchronization of Email and Calendar wirelessly with Exchange Server 2003. If an EAS account exists on the handheld the Calendar conduit will disable itself to avoid duplicates. Go to VersaMail on your Treo650 Select Menu: Accounts: Account Setup Check to see if any EAS accounts exist on the device by selecting and account, then Edit... One the first screen check Mail Service. Do any of them say "Exchange Activ..." If yes you'll need to delete that account to sync calendar entries.
Sep 07, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
228 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
