Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Motor noise excessive, model etowsrxmq03
The motor makes a loud, ragged hum the whole time is is on--which is an awful not of the time. Anyone trying to hold a conversation in the kitchen in the kitchen would have to raise their voice. Must close the door to my adjoining bedroom-study to sleep, rest, think, study--you name it. I'm renting here and this fridge is making me wish I'd never signed the lease. If anything can be done, please let me know. By the way, I see that this model is a "type 3" and uses more energy (386 kwh) than other models. Is this correct?
Many thanks.
  • Anonymous Feb 18, 2009
    Same fridge, same noise. Very, very loud.
    I was able to reduce the noise to about half by removing the 2 1/4" screws in the freezer comparment, removing the panel they hold against the back wall. Reinstalled it with 1/8" foam around all sides.
    So now THAT doesn't rattle.
    I suspect the real problem is that the blower fan is out-of-balance. I'm going to try removing that next to try to find out how badly out of balance the blades are. Plan to remove material from the "heavy" blades until I get it balanced. Will report back.
  • 42 Answers
SOURCE: Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Posted on Mar 28, 2008
  • 33 Answers
SOURCE: Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Posted on Nov 29, 2008
heatman101
  • 43501 Answers
SOURCE: My whirlpool fridge makes a
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 11, 2010
Testimonial: "Thanks for your advice, I opened up the back panel in the freezer and found that it was all frozen over. i defrosted with a hair dryer all good now."
  • 492 Answers
SOURCE: my whirlpool side-by-side model name
make sure a rat or something hasnt got into the fan
Posted on Jan 23, 2011
e-Guru
  • 3917 Answers
SOURCE: I have a 6 y.o. whirlpool fridge wbm 46 model
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 02, 2011
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Sorry to barge in... I have a GE SxS refrigerator, model TFX 22Z RXA . The condenser makes a VERY hard/loud rattle 75% of the time it shuts off. The whole refrigerator/freezer is still working...
One of the compressor springs inside is weak and allows the motor to move sideways and hit the shell that covers it. This condition can be annoying but will not affect the longevity of motor. If you place a shim under the motor opposite the bad spring you may minimize the noise
Sep 07, 2017 | GE 21.7 cu. ft. Side-by-Side Refrigerator...
My model # is LEA 10 AW...Anyone know of this one?? It will not spin on its own.. When you try and turn it on it makes a humming noise, but wont spin...
One of two things its humming because the motor is running and the belt is off/broken in which case you should still feel air coming out the exhaust vent. Or the motor start windings are bad in which case you will need a new motor.. If you have a helper try this open the door have someone hold in one the door switch then have them try to start the unit while you are spinning the drum clockwise, if it then runs the motor is bad
Sep 22, 2010 | Amana LEA11 Dryer
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
May 18, 2009 | Samsung HL-S5087W DLP TV
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Motor noise coming from hp designjet 120 nr
The fan is probably filled with dust. This can throw the balance off and make vibrations or cause resistance which can make a humm, not necessarily a bearing, not sure if the fan even has bearings. Anyway, the intermittent noise can be that the fans only run when the printer is hot. Find where the noise is coming from clean off the blades and components with a damp rag, blow around or lubricate the center of the fan, and replace it in the printer. Should fix it.
Dec 10, 2008 | HP DesignJet 120nr InkJet Printer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
383 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
