Question about E-Machines eMachines Desktop PC
Computer will not start
I moved my computer to a new location. When I tried to turn it on, the power button flashes quickly. The fans start, but the computer will not boot up.
  • locovolador Nov 21, 2008
    i have a similar problem. When I push the power button, the fans just make a small ****, but don't actually start and nothing really happens. The computer was on one day when it suddenly turned off, and now I have this problem. Please help
    Scholar:
  • 152 Answers
Remove and reinsert all cards (i.e. video card, sound card, etc.) as well as fix firmly the cables to the CPU ports. It is possible that these connections loosened during transport.
Posted on Sep 01, 2008
My computer will not fully turn on when trying to turn on, What are some possible fixes?
in my experience it would be the power supply. try changing that out, if that doesn't help, it's time to get a new computer. not worth fixing.
Oct 22, 2015 | Compaq HP PRESARIO CQ5000 2.8GHz 3GB 160GB...
I got this computer from a friend of mine, and he hasnt used it in several months. I plugged the computer in, and the monitor and turned it on. It started up fine, I logged in, and then it asked me if it...
your computer have 2 complaints one. your computer have over heating problem of your cpu. so just remove heat sink and fan of ur cpu and clean after u must put 'heat sink compound on your cpu' after you can install heat sink back.
two, your computer is banded microsoft thats why when u loged on your pc. will ask automatic update so first you must log in to safe mode of xp ..click f8 button when u boot ur computer and login to safe mode.after you can install windows genuine remover you can download it from this site...http://www.brothersoft.com/removewga-download-62674.html..
Oct 06, 2011 | HP Hewlett Packard Pavilion a1016x PC...
AMD Athlon 64 X2 Cooling System Failure: My computer suddenly turned OFF as if it was unplugged. i opened the cpu casing and cleaned the inside hoping it will solve the problem, but when i plugged the...
Hello
Sounds like you need a new cooling fan.You may be able to save yours with some electrical contact cleaner spray.
Remove fan and spray.
The cpu will heat up quick and shut down everything to protect itself.Im sure once you get a new fan you will be up and running again.
You may consider reapplying new conductive paste to the processor while you have the case open.
Aug 09, 2011 | AMD Athlon 64 X2, 2 GHz 4600+...
My gateway computer do not turn on.the fan try to start and stop.what should be happenning?
I think that the CPU fan isn't working as it should and the CPU is overheating quickly. If the CPU is heating too fast, the mainboard is automaticly shutting down the all PC to prevent damage. Your thermal paste might be gone. Isn't the computer giving any sounds or LED flashes ?
Nov 02, 2010 | Gateway 830GM power supply **FREE **...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Hard drive fan stop working computer stop, yes I have power but but,computer will not tyrn on PC will not power up when I woke up this morning and went to use it the green light on the front was flashing...
Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
Oct 24, 2008 | Compaq Presario 5000 PC Desktop
Power not on
  • First if you have move the computer recently, check that nothing has moved inside box and unplug cards if any including memery and replace again.
  • Check switch if working, does it turn on if you hold button? If so New switch required.
  • Most common problem: Power supply might be blown, see if the fan is running in the back of box when you start-up. Otherwise you will need to check a few things before you replace with new one. Check that the CPU fan inside box is running. Check that there isn't dust build up on fan stopping from running. Might need replacing. Try also taking out battery and starting up computer. If all else fails you will need to replace power supply with a 500watt or more power supply. If you have another computer on hand, you could try the power supply from that system as look as it has same connectors and try and run with that. If works then you know what to do. If nothing, the motherboard might be gone, or cpu even. Try also taking memory out and replacing. see if runs.
  • Before you give up, unplug all cables to hard drive, cd roms and DVD-rom and try to turn on
Aug 03, 2008 | Acer Veriton 7600GT PC Desktop
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Dead monitor
Make sure the monitor is connected to the right video graphics card. This will happen if you are using the wrong one. Because at one time someone added another graphics card. Move the computer and put the monitor cable back in the wrong port on the back of the computer.
Jan 16, 2007 | Gateway FPD1950
E-Machines eMachines Desktop PC Logo
35 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
