Question about Dryers
Lg tromm dlg3744 not drying I have to put in two ro three times.
  • 1 more comment
  • tinaw711 Sep 07, 2008
    my dryer is not drying. I have to put each load in at least 2 or 3 times!!!
  • gettinmad Nov 23, 2008
    I have the same problem.  I am NOT opening it during the cycle.  It finishes and the clothes are not dry.  Usually with jeans or towels.  The filter is clean.  I usually have to start it over 2 or 3 times.
  • debra27512 Mar 21, 2009
    our dryer is getting hot but the timer jumps down quickly and the garments are still not dry I tried several attemps on drying but garments are still as I put them in dryer....
  • 706 Answers
In order to help you, you'll need to provide some additional information. You say that the dryer is not drying but when you open the door mid cycle, are you getting hot air in the tub? If you are , then you should check your vent system for obstructuions.. If it is NOT hot then you may one of several things wrong with your dryer. It could be that the igniter is not sparking to produce a flame for your heat or one of your thermal heat senors tripped and needs to be manually reset. You could have an issue with a non-resettable fuse, your gas inlet control is malfunctioning oryou do not have gas coming in. These are several areas ( not all of them) that could cause your dryer to not strike a flame . Also.. the blower may not be moving air or is bound up. I am not sure how much troubleshooting you want to take on yourself but these are the main issues, also: here in aexcerpt from the manufacturers site regarding excess dry times..
When clothes are not dried well even after a regular cycle, try selecting a higher dry level such as Very Dry or More Dry, or try selecting Time Dry with a reasonable drying time. Also check to see that the exhaustion duct is not clogged. Refer to the installation manual of the exhaust vent. When there is a clog in the filter, it may not dry as efficiently, causing longer drying time-which can cause damage to the unit. Here is a link to the mfrs web site and you can get the user manual here.. http://us.lgservice.com/index_b2c.jsp Hope this helps..
Lastly, In all probability the venting system is restricting air flow and that may be the solution.. check the filter and make sure your vent ( including the part that opens to the outside) is not clogged... Good luck..
Posted on Sep 01, 2008
Manual for lg tromm dryer
Hi bbdesertrose..
Go to the following webpage and download your user manual
Please take time to rate me
http://search-manual-online.com/lg-tromm-washer-manual.html
Sep 17, 2011 | Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Our LG TROMM DLG7188WM dryer has no heat
Several things can be the problem.
Is 220v present @ the outlet?
Heat element?
High limit thermostat?
Main computer?
Bad dryer cord? Ect...
Proabably time for a service call.
Jan 12, 2010 | LG Dryers
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryers Logo
571 people viewed this question
Top Dryers Experts
