Question about Dishwashers
Bosch DLX series didn't drain, now no power
I have a Bosch DLX Series (shu3336uc/uc12 FD8202080266) failed to drain completely but seems to have gotten all my dishes clean. Now there is no power or rather the machine does not respond to pushing the start button, I.E. seems like there is no power.
Is there a reset button?
  • 2 more comments
  • gtharris Sep 11, 2008
    Very same problem as listed:
  • Anonymous Mar 09, 2009
    Still have power, but it won't drain or clean properly. Filter is clean and not plugged. Tried doing the test/reset but that didn't fix it...
  • mofem Apr 08, 2009
    same, water won't drain...bailing it out is getting old...how do you fix it
  • hatethem May 03, 2009
    running when I left come home no lights, dishes look clean but water in bottom of dishwasher
    Problem Solver:
  • 6 Answers
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Posted on Dec 27, 2008
  • f1nutz Nov 13, 2010
    I had the same problem. Wiring had shorted out/overheated and melted the maret connectors. I reconnected the wiring and all seems to function ok so far. Also found an olive pit after the machine did a test cycle so that could have been the culprit maybe preventing drainage but not exactly sure. We'll see if it holds up after a few more cycles.
  • wlou3 Feb 02, 2011
    I had the identical problem of water in the bottom and no power. I checked the electrical panel and the circuit breaker was tripped. I opened the bottom cover and the wire nut on the black wire was fried. I stripped the wires and rewrapped them and it worked fine. This is the second time this has happened. Next time I will replace the stranded wires. Thanks for the info.
Have Bosch made Blomberg. NO parts available in Canada. DV pump runs on continuously. Water sensor failure. Expensive repair- replaced with Kenmore due to high risk of fire and NO PARTS available. Avoid Bosch/Blomberg!! Company uncooperative.
Posted on Dec 26, 2012
I cleaned out the entire bottom, used a plunger, then soaked up all the water, stuck a coat hanger down a hole in the bottom, There does not appear to be any debris clogging anything but to be honest I don't see a filter as I know them.
Posted on Sep 01, 2008
  • 78 Answers
Have you unblocked your filter?
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
Bosch vision 300/500 dlx series washing machine: how do you remove the front kick plate to access the pump?
Bosch vision 300/500 dlx series This video will show you how to change the pump washing machine Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 08, 2012 | Bosch Washing Machines
1st cycle pump very noisy. Nothing seems to be drying properly
This means that the drain pump has some debris inside. The drain motor would need to be cleaned. One very common issue on this unit is the control board. The board will often fail and not send power..
Apr 13, 2011 | Bosch Integra 300 Series SHX43C0xUC...
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
Sep 12, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch dishwater backed up/leaking
You may have upset the lower door gasket, a kind of "wiper" that keeps the water inside during wash/ Look for a wrinkel in it. Maybe push it down some. the track where it goes my be you can see and it will be self explaning. As for the water not draining.... A hose kinked, A pumpout drain valve not gettign power, I just had the same problem with mine and found a small piece of a plastic baggy in the pump sump covering part of the drain hole. And after that I had no drain and just squished the drain hose at the outlet. I suspect a buildup of grease or maybe some more plastic was inside the the outlet tube. Mine drains fine now. Look for these. And let me know please
Apr 05, 2009 | Bosch Dishwashers
Dishwashers Logo
2,808 people viewed this question
Top Dishwashers Experts
