Question about Canon PowerShot A75 Digital Camera
Focus Problem Dear folks, I just bought a (new) Canon A75, and it doesn't seem to focus. At all. Even on manual focus, not only can I not get it to focus properly, the focus doesn't change at all. When on AF, it doesn't beep like the manual says it should, and the yellow light blinks, as it's supposed to when there's a focus issue. The focus assist light is working. Can anybody think of anything I should try? The manual is of no help. This is my first digital camera, so I'm not ruling out the possibility that I've got something in the wrong setting, but if so, I can't figure it out. Yes, I've made sure it's not set to macro. Any ideas? --Thanks
I'm not sure on the problem, but one thing to check on the front of the A75 it also uses an IR beam to set focus. It's a little circular dot under the flash on the right side. It will light up red when in use to project the IR beam. Make sure you don't have it covered up. That's my best suggestion. Hope it might help.
Posted on Mar 29, 2006
I have a canon xsi that I have been using successfully for a year and a half. All of a sudden the focus preview is not working. It doesn't matter what lens I am using. I shoot in manual mode. What I...
When you depress the shutter button halfway, you are (in fact) activating the focus mechanism.
If in AF mode, you should hear the 'beep' when focus is achieved.
However, bear in mind that the XSi has three focussing modes: Quick mode, Live View, and Manual. There is a difference in how focussing is achieved between the Quick and Live View modes. (see page 102 onwards of the user manual "using AF to focus").
Also, the barrel of the lens will move during the focus operation.
If this does not happen, then there is a definate problem.
Having images in focus despite having no movement on the lens, simply means that the aperture settings are probably small enough to give sufficient depth of field to include your subject.
Jun 12, 2011 | Canon Cameras
Does not focus corrcetly
Go into the menu, setup menue, hit the reset. This will clear everything that has been set in the menues. If the focus still doesn't work than it is the cameras
Jun 25, 2010 | Canon PowerShot A75 Digital Camera
Will not focus. AF-Point Zoom is on and AF-assist beam is on.
that is the focus lens assembly and the ccd defect
you can return to canon they will fix for free
they post a recall notice on this model A75
...l hope that give you a good help.
May 06, 2010 | Canon PowerShot A75 Digital Camera
Canon Powershot SX10 IS auto focus unreliable
I don't this its an error. I have used this Canon SX10 IS Camera for nearly a year now I haven't had this kind of problem.
Usually auto focus take few seconds to focus on object depending on distance and lighting. That might be the problem ?
Jan 13, 2010 | Canon PowerShot SX10 IS Digital Camera
Have a canon digital elph sd750. Pictures are now blurry.
You could have cracked the lens, damage the focus or a number of other things but the lens and focus are most likely. check your lens for scratches if there is none and no cracks take it to your nearest camera store or buy new good luck!
Aug 08, 2009 | Canon PowerShot A75 Digital Camera
I can't get the macro adapter to work ?
Put the macro adapter on the camera and move the camera in and out from an object to try to focus the object in the display. Remember, macro is very small, very close and very small field-of-focus. I hope this helps.
May 28, 2009 | Vivitar Telephoto 100mm f/3.5 Macro Manual...
Blurred images
i beleave on auto, the a75 has auto focus, there is a 1/2 second focus time before the picture is taken, enough to blurr the picture
Jan 03, 2009 | Canon PowerShot A75 Digital Camera
5d focus confirmation light
Just a wild guess, but in predictive AI focus mode you need a subject in motion for focus to lock and focus adjustment is continous until the exposure is made, in one-shot AF or manual focus mode focus will lock on still subjects. Super nice camera btw.
May 17, 2008 | Canon EOS-5D Digital Camera
Out of focus with blured streaky monotone display.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Nov 18, 2007 | Canon PowerShot A75 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
