Question about Boston Acoustics Duo-i Horizon Clock Radio
Volume is locked
My duo-i is locked at the volume level of 18. How do I unlock it to get more sound?
  • 2 more comments
  • stanananda Sep 20, 2008
    Our Duo-i is suddenly locked at volume level 17. We've unplugged it for several times as somone recomended on another forum but the problem remains.
  • kimfredknox Sep 27, 2008
    the volume is locked on 16. we can adjust lower but not higher. What to do?
  • Anonymous Jan 02, 2009
    Same problem.  Fix worked.  Thanks!
  • Anonymous Apr 11, 2009
    wow...thanks for the help...I was bummed cuz mine locked at 14 today. gotta love this internet for answrs.
Thank you soooooo much!!!
it worked :)
Posted on May 17, 2009
Very good thanks a lot simple to do i have told my 3 year old not too touch my toys again!!
Posted on Jan 21, 2009
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter is an easy fix. All you have to do is turn the volume down to 00, push and hold the volume button in for ten seconds until the unit beeps, than you can turn the volume all the way up to 50, which is the max, and than push the button in again to set it. This will deactivate the hospitality mode for you.
Posted on Sep 30, 2008
  • mclicea Jan 02, 2011
    Gracias por e Apoyo funciono bien!! ya estaba a punto de mandarlo a reparación!
  • tim_herbe247 Aug 06, 2011
    Thank you so much. I thought it would have to be repaired at extortionate cost! This solution worked brilliantly, first time. This feature is not mentioned in the original Boston Acoustics instruction manual, which I still own. Poor show, Boston.
Increase factory volume settings
Customize Android's Volume Panel (No Root Required ...
gs5.wonderhowto.com/.../customize-androids-volume-panel-no-root-req...
Sep 18, 2014 - Capable of theming the look of your volume adjustment interface, as well as ... Boost the Stock Volume Levels on Your Nexus 7 for Louder Sounds All .....Any Other Substitute App for My Mobile - Samsung Galaxy S GT i9003?
Crank your volume to 11 with Volume+ ' Android Central
www.androidcentral.com/crank-your-volume-11-volume
Android CentralJul 3, 2012 - Use Volume+ on your Android device to get louder sound from the speakers, ... 11 so you could actually hear the notifications or boost the volume during calls? ... One the application is launched there are options to change speaker, headset or Bluetooth settings, as well ... "News Writer for Mobile Nations.
Dec 28, 2015 | Cell Phones
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Myphone a919 duo user manual
Hi can somebody help me? Please i badly need some :(
I recently changed my screen lock PIN password, but when i've tried unlocking it again my phone didn't recognize my numeric combination. How could I atleast reset my phone without even getting into it? The phone model is Phillipine's MyPhone A919 Duo
Feb 03, 2013 | Cell Phones
I am not able to control the recording level on lower right screen. When I click on it nothing happens.
Maybe your laptop has buttons that control the level also, if so press them.
Most laptops have keystrokes that control the volume level. Normally you will have to Press and Hold the FN function key at the lower right portion of your screen and the corresponding key that takes the volume up. Normally the correct key will show the icon of a megaphone with the )))) volume signal.
More importantly make sure you have the Recording checked in the Audio Sound Properties.
Apr 21, 2012 | Apple MacBook Pro Laptop Computer with...
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
Volume will not maintain level
To fix the problem, I reset the iPod.
Feb 13, 2009 | Apple iPod MA446LL/A MP3 Player
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Sound setting
There are several complaints in FIXYA and they are all about this same fault conndition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Sep 06, 2007 | GPX HM3817DT Shelf System
Boston Acoustics Duo-i Horizon Clock Radio Logo
3,263 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
