Question about Ulead Videostudio 8 for PC
Easy Cap Colour problem
Hey i have just bought an easy cap 2.0 and i have wired it up the way everyone says and all i get is a green an purple screen when i record my xbox but you can just see movement when E.g playing a game and very blurry and ideas?
Thank You
Kai...
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: easy download
Here is the download page:
Adobe - Adobe Flash Player
Posted on Jun 23, 2008
  • 729 Answers
SOURCE: hi, I bought the easy cap capture 2.1c but I cant
Hi there and welcome at Fixya, the support team (lfete)
try to look here :
ask here the support team:
http://www.szforwardvideo.com/support/index.html
or try to download the Torrent file here:
http://www.sumotorrent.com/en/details/3159268/Easycap-USB2.0-Driver-2.1c.rar.html
how you manage a Torrent file you can get more info here :
http://computer.howstuffworks.com/bittorrent3.htm
http://computer.howstuffworks.com/bittorrent.htm
AND you need a .rar extractor you can get one here :
http://www.7-zip.org/
Direct Download link :
http://sourceforge.net/projects/sevenzip/files/7-Zip/4.65/7z465.exe/download
Hope it helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Posted on Feb 20, 2010
I have an Armstrong Concept 1000 that has an AO Smith condenser fan and the purple wire has come off. There are 3 wires, black, brown and purple. Black is connected, Brown connect sto capacitor and where...
Purple goes to the run cap.Trace the brown wire to the cap.The purple wire plugs next to the brown.The cap has letters on top of the can plug it on the COMMON post.
Dec 08, 2010 | Heating & Cooling
My 1998 Ford Explorer alarm goes off for no reason
Grounding the purple / green wire will permanently disable all alarm functions: (thanks alltech alarmman)
I found the elusive Purple and green wire by:
1) Remove the plastic kick panel on the left of the drivers side foot well
2)remove the plastic trim that extends along the floor by the door and up toward the fuse box.
3)pull back the plastic trim that runs along the door entry.
4) pry up the black wire track top.
5) this gives you good easy access to a bundle of wires in that track.
6) cut away the electrical tape to spread open the wires inside.
7) find the skinny purple, and almost yellowish green wire.
8) splice in a 2 foot section of wire, and run it back to the green grounding bolt exposed in step one.
9) replace trim,
Oct 12, 2010 | 1998 Ford Explorer
I need the wiring diagram for a pioneer avic-n2! i need to know which colors do what!
Pioneers wiring is easy. Red is ignition-Yellow is battery-Black is ground-Blue is remote for amp or antenna-Orange is illumination-Speaker wires are usually grey, grey w/blk stripe-white, white w/white stripe-green, green w/blk stripe-purple, purple w/blk stripe. Green and purple is rear, white and grey is front
Sep 18, 2010 | Pioneer AVIC-N2 Car DVD Player
Colour codes for 83 corona, wiring stereo
Hello!
POWER
Constant +12=Blue/Yellow...Switched +12=Gray
Ground=Brown...Illumination=Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru............Saailer
May 28, 2010 | Car Audio & Video
When on charging craddle the keyboard flashes one time green and threetimes red. and it is not charging properly. what to do?
Be honest have you dropped it? If so you should check the cap under the sleep/half moon key top left button. I was on my 2nd kboard and had the same thing happen as you are experiencing TWO times.
Opend it up and found that a small cap under that key was off, its held on to posts without "real" solder. Logitech uses a cap to bridge these connectors with "wire glue". Its real easy to dismantle and i know they say its a 3 year warranty but they LIE. For the 1st board i "fixed" i used a lump of solder bonded to the 4 posts and bought wire glue for the 2nd keyboard. Its an easy job
May 23, 2010 | Logitech diNovo Edge 9676850403 Keyboard
I just purchased an fse1028sf to replace my faulty fan motor. I purchased it from a a/c supply store. My existing fan only had three wires. They were brown, black and purple. Black to: capacitor "c"....
Hi, this is a different wiring diagram then what you have . The 2 brown/wht wires are for the run cap only. Black and white are t-1 and t-2. They sold you a motor that takes its own run capacitor to run it with just both brown wires. Take the diagram from the new motor back along with your original. They will give you the right run cap to go with this motor. Yes, the red wire is power to fire your existing cap and old motor. You will need another cap to run this motor. Don't put the 2 brn/white striped wires on the old cap! They have to be alone on there own run cap. Go back to the parts house and they will show you very fast the wiring diagram and give you the cap. This is a very easy fix when they give you what you need. Keep me posted and ask them to give you what you need to run the motor. A 5 uf run cap perhaps?
Keep me posted.
Shastalaker7
May 03, 2010 | Heating & Cooling
The camcorders show no picture and keeps flashing lens cap but the lens cap is not on?
Download service manual and diognose problem its easy like ABC you might need a new CCD or another part has failed and has to be replaced just order part online its posted to you and fix it your self school stuff easy peezy this is how everybody does it it will say on service page why the camera has no image and flashes on screen messedges you can always put it on ebay hey dont forget to throw in service manual as well
Jan 31, 2010 | JVC GR-D32 Mini DV Digital Camcorder
Sputtering after car warms up ,seems like a misfire every so ofte
it should be pretty easy...one wire at a time is the way to go....just hold the old cap with the wires still attached in the same orientation as the new cap installed, and swap the wires from old cap to new 1 at a time....hopefully it fixes you sputtering problem
Feb 22, 2009 | 1990 Toyota Corolla
Hey
real easy - you need a phillips screwdriver- new cap and rotor button- digital camera. real easy take the wires of one by one and reconnect to new cap.Watch for markings on cap and work your way around. Now pull button and install new one . Put distributor cap back on and tigthen screws- do not over tigthen.Now look at the pictures you took and compare do wirees all go to same plugs as before? If so start car - if not fix by switching wires. Note if you do not match them up exactly and start car- you can bend the valves thus destroying engine. So be sure or get book . I know it sounds scary but is a real easy job .Just do one step at a time . Do not be a cowboy and pull all wires at same time -have fun and let me know how ya do
Nov 12, 2008 | 1999 Honda Accord
Ulead Videostudio 8 for PC Logo
707 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
