Question about Palm i705 Handheld
I am unable to HotSync and cannot load HotSync manager
I am unable to choose a USB connection, HotSync or load HotSync Manager. The Palm desktop organizer program is installed and loads properly. Also, I am networked with the company intranet. I loaded the software from the Palm website since I forgot my CD with the software. Any help would be appreciated.
5 Suggested Answers
  • 473 Answers
SOURCE: How do I switch from HotSync with Palm Desktop to HotSync with Outlook?
I believe you need to un-install the Palm software and then re-install it - make sure you use the Custom Install - as that is where the "Sync to Outlook" box is to be checked
Posted on Sep 11, 2005
  • 473 Answers
SOURCE: How do I activate my handheld for a specific user account?
Definitely something to address with Audible Digital Rights Management of Audible files is controlled and managed by Audible. In general the way these schemes work is to write some kind of key or token file to your handheld when you first setup your Audble account. Unless the keyfile is present, the player will give you the response you mentioned. With Audible, you can move the authorization from one device to another by deactivating one device and activating another. In your case, you seem to have deactivated your Zire 31 somehow. I suspect that you may have put a new user on the Zire 31 and therefore the DRM keyfile is no longer part of your files on the Zire. It would be associated with the old username and no longer on your handheld. I suspect what you have to do is re-authorize your Zire 31 using the Audible Manager on the PC.
SOURCE: palm z22 usb cable connection problem
Hello Every body,
I had the same problem, and went to the device manager. It said the driver was gone. So to solve this, Just uninstall, and reinstall the software. And it will Sync. at least it did for me.
Hope this helps,
Dakotah
Posted on Aug 13, 2008
Just_Bobz
  • 448 Answers
SOURCE: cd doesnt install palm desktop software (palm z22)
You're saying you trying to install an appointment on your PDA. Has evrything worked before?
Posted on Jan 01, 2009
gemmy23
  • 346 Answers
SOURCE: My Palm Z22 used to hotsync with my computer. It
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Posted on Nov 19, 2009
0 characters
1 Points
Unable to connect with desktop through usb cable
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Dont have Cd
www.palm.com should have the downloads for PALM DESKTOP.
Feb 27, 2009 | Palm Zire 21 Handheld
I reinstaled the Palm Desktop again it worked....
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
Palm will not sync
Make sure hotsync manager is running. reboot the Palm device. connect to the USB cable and press the button. Also use hotsync manager to ensure you have enabled USB option.
Jul 23, 2008 | LG KU990 Viewty
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm. http://www.palm.com/us/software/palmsoftware.html
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Jan 27, 2008 | Palm Treo 600 Handheld
Hotsync disconnects my LD
I've had this problem getting these set up in the past for customers.
What you want to do is go to your device manager and sync the palm while the window is open.
Look for a yellow triangle with an ! in the middle of it down towards the bottom by USB controllers.
If it pops up, double click on it and go to the drivers and try to reinstall your driver.
Sep 03, 2007 | Palm LifeDrive Handheld
USB Connection
Do you have the USB option turned on in the HotSync Manager? Have you checked the item called Local USB in the HotSync Manager menu. This check mark ensures that HotSync Manager is listening to the USB ports on your PC for a HotSync request.
Sep 12, 2005 | Palm m130 Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Open Questions:
Palm i705 Handheld Logo
19 people viewed this question
Top Palm PDAs Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
