thanks jdumalay09 , but i need to download a soft copy of the operating manual, my microwave is still new and never used, but i don't know how to use itthanks jdumalay09 , but i need to download a soft copy of the operating manual, my microwave is still new and never used, but i don't know how to use it
In our case, the error code was displayed on a KitchenAid microwave/oven combo. It turned out to be a $4 fuse called the "Main Cavity Fuse". Good luck.
none release microwaves and they all use the same technology ( high frequency radio waves)
consider one that is simple to use as fancy do dats all fail in a power outage
I have a problem with my Kenwood CK404. When I put either oven on (it's a double oven), once it gets hot it starts to make an awful noise. At first I thought it was the fan in the main oven. But it makes the same noise in the small oven, which doesn't have one. Does anyone have any suggestions of what the problem could be? Kind Regards
Trotwood
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top.
Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above).
Venting (outside ot inside), and attaching method.
Though they're simple in concept to install, it's a bit awkward in reality.
The main thing you need to determine is sufficient space between the MW and the stove.
You will have to check, but I believe you need 18" beneath the microwave.
Many companies have brackets for that purpose.
