Question about Casio QV-R4 Digital Camera
Lens Error I recently had a problem with my Casio QV-R4... every time I'd turn it on, the lens would retract and I'd get a "LENS ERROR" message on the screen. I talked to customer support and they told me that Installing the new version of their firmware, v1.01 would fix this problem. I've since installed the new firmware version, but I am still receiving the lens error. Has anyone else encountered this problem? Does anyone know how to fix it? Please help!!!
As solutions 1 & 2 indicate, lubing the gears works!! This is a great camera, so I hope all of the QV-R4 owners try this. I may become a maintenance item for the camera.
I have a few additional tips.
The gear that needs to lube is larger black gear driven by a small white gear. To get to it, only the back cover needs to be removed (don’t take off the flat cable to the back case; it’s a nightmare to put back on). There is a small motor on the bottom of the camera. The motor drives a small white gear that in turn drives a larger black gear. The black gear is hard to get to. To lube it, I used a hi-tech dry bicycle lube and a very small paint brush w/ long bristles. I also turned the white gear a few revs to be able to coat the black gear better. This may have helped get past the sticking point on the black gear.
After two attempts the “lens error” was gone, but the white gear was still having problems turning the black gear. This set of gears appears to focus the camera, hence the image was blurry. Some more lube and spinning of the gears and the problem was gone. Gone I said, gone.
My beloved camera is now back in service. Total time to fix, 30 minutes (I actually took a bit more apart than I needed to J )
Posted on Dec 09, 2007
Even though I had the newest firmware installed (which can prevent from the lens error problem in some cases) after 6 years of usage I also had the lense error. As it was out of warantee and useless whith the lens error I decided to try to fix the problem by opening the back of the device. Swithcing on the QV-R4 while the back was opened I saw that the tiny white cogwheel below the LCD stuck and did not turn. All I did then was turning the cogwheel manually but carefully into one direction (as it was only stuck into one direction). After that it worked fine again. Now I am a happy QV-R4 user again :-)))) P.S.: Please consider this only as a report of my successful try to fix my QV-R4. Feel free to try the same, but at your own risk.
Posted on Sep 14, 2007
Hi. (copying my post here that I first posted at http://public.ok2life.com/comment/index/26 ) ... I had this same problem on a Casio QV-R4 - which has been a great camera otherwise - and managed to FIX it !! . Exact symptoms of my problem: on start-up, lens would extend to about full length, then I would hear a quick clicking/whirring sound of some kind of gear/cog failure. Next the lens would retract itself, the LCD screen showed "lens error" and the machine would power-off. MY FIX (might not work for everyone): Seeing it was way out of warranty AND has fungus on the lens anyway, I took the back off and started the cam... over and over, looking for the problem. Eventually I could see that down at the bottom of the Cam, on the Lower right side of the LCD the is a small white plastic cog which made the strange noise. Next to that (it's very difficult to see) the white cog drives (?) a larger black one - it may be something to do with the focus mechanism - but thats just a guess. Trying to move the cog gently with a tiny screwdriver I could feel that it got stuck on a tight spot once every revolution in the same place. Tried to work the tight spot out with no luck and thought - "what the..." I'll squirt a tiny drop of WD fluid in there on both cogs (seeing the camera was useless to me at this point). Lo and behold a few minutes later the camera started just fine, lens extends and contracts properly with NO ERROR!!. So ... if your Casio QV-R4 is out of warranty and otherwise headed for the trash can try this - it just might work. ## NOTE - I'm 100% certain that no Digicam manufacturer would recommend using oil in your camera. It would most probably void all warranties. If you do it - use as little oil as possible and apply it to as small an area as possible. Wipe off any excess after. The only reason I tried this was because the Camera was otherwise out of warranty and useless to me as it was. - Now at least it works - but I still need a solution for fungus on the lens!!Anyone interested came e-mail me at dukey_e(AT)yahoo.com.au (use @ symbol obviously!!). good luck - E
Posted on Jun 02, 2007
    Sergeant:
  • 255 Answers
Yeah, apparently the firmware update prevents the problem from happening. It doesn't actually fix it. I sent it to customer service and it was going to cost $250 for them to fix it. It should be covered under warrentee but I didn't have mine...now I'm out a camera. good luck, sorry for the bad news.
Posted on Sep 12, 2005
    Master:
  • 473 Answers
I also have the same problem, called Casio, they said it is a circuit board problem that causes the lens error, and that the part costs about $260. A firmware update after the problem will not fix it, the update was just to prevent the problem. Unbelievable!! Never buying a Casio again, will stick with Canon.
I have a casio digital camera qv-r52 3x optical zoom when I turn power button on it will not stay on the lens retracts but I can view the pic's on the dish
Katie, Joe alerted me to your problem. The symptoms that you're experiencing suggest that you're experiencing a lens error. Lens errors are fairly common, but there are many causes. Some causes include poor or drained batteries. Or sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 16, 2011 | Casio Cameras
Lens error and green light flashing
Greetings,
power related issue.
check your batteries - charge or new
fxnlogo_s.png Technical Support, Instructions & Repair Service
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Can i use a 4GB SDHC card in y Casio QVR30 camera
According to the product specs on Casio's website No, sorry
Mar 07, 2011 | Casio QV-R4 Digital Camera
Lens error of casio EX Z300
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Resetting EX-V7 error message
Hey Go here
http://world.casio.com/qv/download/en/ex_v7_firmup/
Download the latest firmware. Install it. Like the rest of the people. It seems like we all dropped it. And updating the firmware seems to help a bit.
Meaning you can now use tha Camera and take pictures, but when you turn it on, you will get the same error message for like a second. Then the Camera is back to normal.
If its under warranty take it back. And dont tell them it was dropped.
Cheers !
Mar 14, 2008 | Casio Exilim EX-V7 Digital Camera
Casio Digital Camera QV-R40 (System Error-0e01)
"System error" always needs to be sent into repairs. Give them a call and see what they can do for you. 800-706-2534 and then keep choosing option 1.
Jan 09, 2007 | Casio QV-R40 Digital Camera
Casio QV-R4 Digital Camera Logo
144 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
