Question about Optoma RD65 65" Rear Projection HDTV
Replaced bulb stil issues
I ordered an e23 5kv precharge lamp from ebay. replaced bulb (even tho old one doesnt look burnt out) and tv still tries to power on, whines and then solid lamp light comes on.
any ideas?
  • 3 more comments
  • onemoodybizn Sep 01, 2008
    thanks ill try that tomorrow ;)
  • GotBass Sep 02, 2008
    same problem .. bought the tv thinkin it needed a bulb .. bought one from deadlamp.com .. after hours on the phone with optoma, it was the wrong lamp for the rd65 .. sent it back .. bought the right bulb from optoma .. $400 .. still doesnt work .. the optoma tech said the wrong buld could have burnt the ballast up .. awsome .. i just hate to buy the ballast and it not be the problem .. so it sits in my garage taking up space :) .. kewl
  • SendTedEmail Nov 04, 2008
    Hey I've got the same issue as you do, tv whines three or 4 times, but
    then I get double solid reds, I even have the new 5kv bulb but now I'm
    wondering if the old bulb is good. Did you ever end up finding a
    solution? If so I'd love to hear about what you did. Also do you have
    any idea what is what in the back of the RD65, I'm pretty computer
    savvy I can build them and what not, so if I just knew what was what, I
    could probably replace the part that it needed. Any assistance you
    could offer would be greatly appreciated!! Thanks!
    -Ted
  • lisaalehman Dec 27, 2008
    My optoma is doing the same thing, just replaced bulb still wont come on. Has anyone figured out what to try next?
  • onemoodybizn Feb 17, 2009
    anyone know a good repair place for optoma tvs in Arizona? i cant find anywhere to work on mine :(
    Sergeant:
  • 293 Answers
In most projection televisions if a solid light comes on there isn't anything wrong the bulb there is a problem with one of several cards in the back of the television. I'd check for over heating damage on your imput cards, the Controller card that is connected to said input card, or the relay card that controls the tube output. Keep in mind you did order a part off of Ebay which is untrustworthy in and unto its self.
Posted on Sep 01, 2008
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
LG 44SZ8D not turning on
The red light indicates the lamp is burned out. A new one is $100 to $200.
Depending on whether you use the old housing or want to order the lamp and housing together. There are lots of sources for this lamp online.
Once the lamp is replaced, it will be good as new and the lamp will last aprox. 8000 hours.
Apr 06, 2009 | LG DU-62SY20D 62" Rear Projection HDTV
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Jul 11, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma RD65 65" Rear Projection HDTV Logo
234 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
