Question about Palm Treo 650 Handheld
Treo 650..In contacts, how do I delete many at a time instead of one at a time
I have pages of contacts that i dont want on my treo 650. How do I delete many at a time.......can you hold down a button to select from point A to point B as you can with outlook email??
    Master:
  • 473 Answers
I suggest that you create an additional subfolder under your main contacts for your master contact list and use the main contacts file as your list for syncing with your treo. Once you have your contacts moved around you need to change your setting on the sync to have your pc override the handheld. I use pocket mirror to sync with and it's a fairly simple setting to change. I would also suggest that you export your contacts to a back up .pst file before doing the sync. If it messes up on you with duplicates or something you can alwaws just delete the contacts and import them from your back up. I recently cleaned up my duplicates on a treo 600 using this method.
Posted on Sep 12, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Tip
HOW TO PERFORM A HARD RESET ON Treo 650
Performing a hard reset on a Treo 650will erase everything on the smartphone. Most people do this because of trouble with the Treo 650's software. There are several key stages to performing a hard reset. Follow these steps to learn how to do it properly.
  1. HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
  2. Step 2 Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
  3. Step 3 Let go of the red phone button when you see the Palm screen.
  4. Step 4 Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
  5. Step 5 Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
  6. Step 6 HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
on Sep 17, 2009 | Palm Treo 650 Handheld
How do I do a hard re-set on a Treo 650?
Try this eHow page:
http://www.ehow.com/how_2066667_hard-reset-treo-650.html
Dec 24, 2010 | Palm Treo 650 Handheld
Language settings
Bueno, trata lo siguente:
If you purchased the Treo in the U.S., you should have the English to Spanish option when you reset the phone. Just make sure to back up your data before resetting it.
Step2Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset. Step 11Let go of the red phone button when you see the Palm screen. Step 2Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset. Step 3Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone. Step 4HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Do not forget to back up your data before performing the hard reset. If you don't, only the data from your last HotSync will be able to be recovered.
  • After performing a hard reset, install your applications one at a time to make sure each is in working order. Delete any applications that are not in working order, as those might have caused the need for the hard reset in the first place.
Buenas Suerte,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Joe Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 22, 2009 | Palm Treo 650 Handheld
Palm treo 650 phone
Greetings to all. I have just purchased a palm treo 650. It was unlocked so I was told, but it was not a GSM, It was a CDMA, My carrier is T Mobile and I dont know what I could to Make It Work, as t mobile has a sim card and this treo 650 does not. Is there any thing I could do to solve this problem?
Aug 28, 2008 | Palm Treo 650 Handheld
TREO 650
Im not sure about your model but, select them all first and then add to sim?
You might need a program todo it for you thought.
May 01, 2008 | Palm Treo 650 Handheld
Palm Treo Rebooting After send an Text/SMS
Hello, hope it helps (from http://www.chaddickerson.com/blog/2006/05/19/what-to-do-when-sending-an-sms-makes-your-treo-650-reboot/)
The application that causes the reboot varies, but it’s always the same error related to the message store. Here’s how you fix it (and beware — this deletes all the text messages on your device!):
  1. If you don’t already have it, you need to download and install FileZ on your Treo. All this does is give you access to all the files on the Palm OS filesystem. This is a tool that must be used very carefully, since you can move, copy, and delete any files on the Treo, even ones you didn’t know were there. It’s one of the most useful Treo utilities you can have.
  2. Run FileZ on your phone and choose “View and Edit Files.” In the next screen, you should see “Internal” under Filename. It might also say “ROM.” If you have an SD Card, you should also see “External” or “SD Card.”
  3. Click on the little wedge beside “Internal” to expand the list of files on your Treo.
  4. Find Messages Database and delete it (you do this by checking it, choosing “Details,” and then clicking “Delete”)
Apr 01, 2008 | Palm Treo 650 Handheld
Buttons not working properly
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 15, 2008 | Palm Treo 650 Handheld
Help out a New User
all you need is to sycronize it. page 33 in the user guide: http://www.fixya.com/BrowseManual.aspx?mnlid=945&prdid=289812&__PAGED_=33
Nov 16, 2005 | Palm Treo 650 Handheld
Deleting Outlook contacts
FileZ file utility lets you delete the AddressDB on your Treo Your best bet would probably be to wipe the Contacts database on your Treo 650, then re-sync. 1. Install FileZ on your Treo 650, Why? Because the Contacts DB is not accessible from the built-in system; you need this extra file manager to delete it. 2. Launch FileZ and find this item: AddressDB. 3. Tap on AddressDB to add a checkmark next to it. Hit Details. Hit Delete. 4. DON'T HOTSYNC YET! Just in case, export your Outlook Contacts and store in a safe place. You'll be syncing to a blank address DB on your 650, and although it shouldn't overwrite your Outlook data wwith the blank DB ... better safe than sorry. 5. Now you can HotSync to Outlook.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
310 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
