Question about Magic Sing Along Consumer Microphone
Won't turn on
I just bought a magic sing digital karaoke, ed-8000 series in Jan 2008.
All of a sudden it won't turn on. Whats wrong can you help ? The dealer wants to sell me another one.
  • 2 more comments
  • linakamm Sep 04, 2008
    The dealer said the warranty was only good for six months.
    I bought new batteries and the dealer tested the microphone with a new set of wires. Still not working.
    Can't find anyone in Hawaii to service the microphone without them charging me almost half the price of what I paid for the microphone. Clicked on your listing and everyone is on the mainland u.s.
    I'm still looking for someone in Hawaii to service and repair my microphone.
  • 1,879 Answers
Magic Sing products don't last long
Common problem is it just die out
Costs more if you try to have it repaired, manufacturers website don't even show up in Google's result
Posted on Oct 04, 2008
  • 19,396 Answers
If the fault is only the microphone, and it works with a different microphone, you can just replace the microphone, the price for a replacement microphone is generally not too expensive.
You should also contact factory to find out how long guaranty cover is. Many chinese manufacturer do not provide support at all, but if there is any factory guaranty cover, that should last one year.
To find out warranty term, contact factory here.
    Master:
  • 479 Answers
There is a repair/service column on fixya main page .just enter your proper zip code in that column and the nearest repair center for your device will be listed with proper address and telephonenumbers.you can contact them and tell them your problem.they will say you the charges for reparing.and take your address.and will be done.
    Genius:
  • 2,035 Answers
You micro phone is covered with one year warranty :
The majority of electrical malfunctions are covered under the 1 year warranty, with the exception of the following things:
1. Tampering with the microphone (opening the microphone and trying to repair yourself or by a non-authorized Enter-tech repair center).
2. Battery leakage or explosion of batteries
3. Water damage
4. Physical or cosmetic damage includes and not limited to dropping the microphone, throwing the microphone or severing any of the wires because of misuse.
This by the company ,you can contact the company get it serviced if this above statements are not true...
Please use this link:
http://www.uskaraoke.com/repair.html
Good luck....
Posted on Sep 04, 2008
    Genius:
  • 1,665 Answers
As long as it is not working you can also try a Compatible wireless microphone for duets/backup singers for Magic Singalong Microphone ED-8000 and ED-9000.
Unfortunately its main board may has a cold solder or bad component and troubleshooting and repair costs more than replace it
Good Luck!
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Sep 04, 2008
    See also correct installation instructions:
    1. Connect Magic Sing RCA cable to a TV 2. Connect cable to Magic Sing (when you connect the cable, please make sure the arrow on the cable points to the top)
    The arrow on the cable jack must be in line with Magic Sing key pad. Insert with minimal force. If it is in correct position, you will hear click sound when Magic Sing is successfully connected.
    3. Use with Power Adapter: Connect the power adapter to female cable adapter jack on RCA cable.
    Use with batteries: Open the back cover of the microphone and add 4 x AA batteries (Alkaline batteries).
    4. Turn on the TV and set the channel to video (external input) mode.
    5. Turn Magic Sing power ON.
    6. When TV displays picture, select a number of song, Magic Sing is ready to start the music. When you press start/stop button once, Music will start. When you press the button again, Music will stop.
    7. You may find microphone functions in product summary page.
    8. If there are only two input jacks on your TV (mono TV), put the yellow plug into the yellow jack and put the red or the white jack into the other jack.
  • 2,071 Answers
Replaced that wires that is the common problem of that microphone,theres maybe breaks or cuts cannot be seen.Try to replaced a new wire cables..
Hope this may help you ;
Regards,
VOTIT
    Scholar:
  • 163 Answers
Make sure it's on/off switch is working
  • 535 Answers
Cheak the power adepter or power code might be damged if it working fine the chak the on off switch its has been has a lose connaction if its poper then chak the curkit pannel of power supply stage
    Brigadier General:
  • 6,966 Answers
Two possibilities other than those posted:
  1. defective/corroded battery contacts/wiring. It may be needed to clean/scrape or bend/stretch the battery contacts to provide more pressure to the batteries;
  2. defective on/off switch.
Both are relatively easy to repair but of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 521 Answers
Get it replaced if under warranty.if the circuit board in the device is faulty.it is worth getting new.
check batteries if the battery is over replacing the battery may work.
if it suddenly stopped without any physical damage happened to the device it could be the battery or the moisture on the main board.replace the battery and get your device serviced.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
    Master:
  • 763 Answers
Did you check the battery of it and did you use a new one?
where did you bought that and is your device covered with warranty?
if it has a warranty then send it back for a replacement or repair service.
CHARCOIS
  • 13,433 Answers
The microphone does have warranty. unless you bought this as used, you should get it replaced or repaired.
    Scholar:
  • 125 Answers
I know it sounds silly, but have you replaced the batteries? Do you have your receipt still? Maybe it is still under a warranty of some sort? As for that dealer, maybe he could let you exchange it if you have a receipt?
  • Mighty B
    Mighty B Sep 03, 2008
    TROUBLE SHOOTING
    If MAGICSING doesn't power up
    A. When you are using the adaptor
    Please make sure the adaptor is plugged into the power outlet correctly.
    Check that the male plug if it is properly inserted into the female jack.
    B. When you are using the battery
    Please check if the battery type is AA. and If battery life is low, MAGICSING
    may not power up or work properly.
I want to convert an xkr file to mp3
you can download a player to play this files on theur website
http://www.sing-magic.com/
Jan 28, 2013 | Audio Players & Recorders
How to connect enter tech model ls 3700T karaoke to tv
connect the RCA-cable to the TV one by one;
yellow (video),
white and red (audio).
Change the TV mode to "AV" or "Video" after
the magic sing is turned on.
Oct 03, 2012 | EnterTech Enter Tech Magic Sing Mic...
Magic sing service center in mandaluyong or pasig
Hi jun64. Magic sing service center can be contacted and located at the following places you are asking for.
In Mandaluyong:
ASERCO SERVICE CENTER
Unit J Facilities Center (Infront of BPI and BDO Wack-Wack)
#548 Shaw Blvd. Mandaluyong City
(02) 718-0493
(02) 718-0496
(02) 716-0499
And in Pasig:
(Head Office)
#18 Evangelista St. Santolan Pasig City
(02) 682-7679
(02) 647-5375
(02) 681-9739
I hope your magic sing will be fixed soon so you can start singing again! Have a nice day!
May 24, 2011 | EnterTech Enter Tech Magic Sing Mic...
2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Aug 20, 2009 | Magic Sing Along Consumer Microphone
Repair shop IL for karaoke microphone or magic sing microphone
My magic sing karaoke mic dont have any sound or data at all
Jan 02, 2009 | Audio Players & Recorders
ED-9000 freezes
try removing the song chip( if your using one)
test the mic with its built in songs...
if it works- then the problem is on the song chip- try cleaning it......
customerservice@magicmic.com
Jan 01, 2009 | Magic Sing Along Consumer Microphone
My magic sing karaoke ed 8000
My frined take it back to her counrty Where she brought it
Jul 28, 2008 | Magic Sing Along Consumer Microphone
Broken karaoke mic ed8000 model
Hi im joe,
if the screen says no font, no picture, no song data it means all the data installed was lost. you have to send it to the nearest service center to have it reprogram.
Feb 24, 2008 | Magic Sing Along Consumer Microphone
Not working Magic Sing ED 8000
its better for you to bring to electronics technician.maybe only ur ac adaptor was burn.
Jan 04, 2008 | Portacom Porta-Com COM-60FC 6 Headset...
ED-8000.
You can not because the songs are in different format. the only thing that you can do is to use recording chip, insert in magic sing, record some songs or record your singing then upload it in your PC using the download manager CD and USB cable
the unit comes with a cd download manager (window XP) and a USB cable. the you can uploaaad your recorded songs in your PC.
Dec 11, 2007 | Magic (ED8000) Professional Microphone
Magic Sing Along Consumer Microphone Logo
776 people viewed this question
Top Magic Audio Players & Recorders Experts
conquer111
Level 1 Expert
Barbat Nae
Barbat Nae
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
