Question about JVC AV-56WP30 56" Rear Projection Television
JVC AV-56WP30 56 Convergence Problem
I changed both Convergence IC's, plus a resistor that was burnt. But now when I try to go into menu to adjust convergence. I just get a black screen. I was reading about how I have to save my setting to memory, but I dont't know how.
I start by pressing the service sw (s801) button on the convergence board and I get the screen for convergence adjustment, but don't know how to adjust it.
  • 1 more comment
  • blackrob24 Sep 01, 2008
    Ok, when you say not fitted properly, does that mean not solder properly?, or just switch the places of the IC's? I had STK 110's before and changed them for 150's.
    Alright, do I follow the manual for convergence adjustment, or do I switch the IC"s vice versa, or both?
    I changed both chips.. Still have the problem. Before, I was able to access the convergence screen, you know the screen with all the + signs? Now I can't. I select convergence from the menu, and I get a black screen. Do I need to save something to get my convergence screen back, or did something go wrong with the repair?
    Genius:
  • 1,268 Answers
Re-do the sodlering on the convergence IC maybe there's a shorted pin. Please the follow the manual for convergence adjustment
Posted on Sep 01, 2008
    Sergeant:
    Champion:
  • 214 Answers
Refer to this link .................................http://www.eserviceinfo.com/index.php?what=search2&searchstring=AV-56WP30
    Master:
  • 521 Answers
The --ic --has not been fitted properly.
  • tech expert12 Sep 01, 2008
    it would be viceversa of what it is fitted so please make it proper.
    or it will be damaged after further use of --ON/OFF again.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
    its the common problem of the ---ic-- not fitted as required.
    thanks.
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
Replaced IC chips, but can't fine-tune convergence.
U know how to use a multimeter right?Check and replaced all the resistors near the 2 convergence ICS.Most resistors are big and blue core in colors.
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Oct 30, 2009 | JVC AV-56WP74 56" Rear Projection...
Convergence is off on jvc av-56wp30
You will need to install a convergence repair kit which contains two Convergence ICs STK392-110 and then the associated resistors as usually a JVC will Need at least 1 or 2 of the resistors when the ICs fail. You can get the kit for your model at the following link which has the IC and all the resistors plus step by step detailed instructions on how to do the repair. This kit fits your model JVC
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Jun 18, 2009 | JVC AV-56WP30 56" Rear Projection...
I have a jvc av48wp30 tv and need a wire diagram
Looking the convergence board from the side of the resistors (The chips will be behind the resistors), you have from de left to right:
1.5 ohms, 150ohms, 220ohms, 2.2ohms, 3.3 ohms, 220ohms, 1.8ohms, 220ohms, 150ohms, 150ohms, 1.5ohms, and dispose horizontal in relation of the other resistors (the one near to the Ic is 2.2ohms and the other is 220ohms).
Hope this helps...
Feb 02, 2009 | JVC AV-48WP74 48" Rear Projection...
Double picture
does your TV has the stat adjustments in the CRT or near the chroma IC it is a trimmer resistor or a rheostat try to adjust it...
Jul 26, 2008 | JVC AV-56WP30 56" Rear Projection...
Green bent line on 48 inch jvc
Check for a burnt resistor on the convergence circuit board. This is usually what happens when the green gets distorted as the green is not adjustable only through the service menu so its either a burnt resistor or a leaky capacitor. Resistor is far more likely. Let me know if you need any further information.
Jan 24, 2008 | JVC AV-48WP74 48" Rear Projection...
Is this a convergence problem?
This sounds like not only convergence but also bad resistors on the convergence board. There are several resistors in the convergence area, I would change the convergence amps and have the resistors replaced. Look for burnt resistor or just colored differently than the others. check also for loose connections. you can tap on safely converg. board and see if problem changes.
Aug 13, 2007 | JVC AV-48WP30 48" Rear Projection...
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
212 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
