The main power light comes on, but I get nothing when I press the power button.
  • alkerrigan Sep 01, 2008
    No.
    How do you get the back case off of a Pioneer SD-P5913 projection television?
    Sergeant:
  • 293 Answers
Is the screen not coming on at all?
Posted on Sep 01, 2008
  • Kristoffer Martin Sep 01, 2008
    Sounds like a bulb burn out. I'd open the back case and take a flashlight and look to see if you can see the bulb/or bulbs dedpending ont he projection tv you have. If you have a burn out then you need to replace it.
  • Kristoffer Martin Sep 12, 2008
    The rear panel should come off with the removal of about six screws. However, i would suggest you take it to a professional for repair as there are elements in the back that are dangerous to work with if you do not know what you're doing.
My tv wont turn on when i press the power button on the tv ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 03, 2014 | Philips Televison & Video
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
Lg 47lc7df tv blinks green light, no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 27, 2017 | LG 47LC7DF 47 in. LCD HDTV
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
Hi i have an advent 9515 laptop which when u press the power button the power light comes on but nothing else. Ive tried with the mains adapter connected
Most cases this is a sign that you CPU (main processor) has failed. this could be due to over heating. This will need to be repaired at a local computer shop.
May 27, 2011 | Computers & Internet
I am attempting to instal a Canon iP4700. Step 3 in the instruction booklet states 'Make sure the Power lamp lights green' After connecting to mains and pressing power button the green light comes on for a...
First try taking the inks out and the printhead and see if power stays on. If so you need a new printhead. the part number is on the side. If not, sounds like a bad power supply.
Nov 06, 2009 | Office Equipment & Supplies
Green led mains light comes on, battery amber light rapid flash
This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
Hope this helps!
-- RT
Aug 26, 2009 | Toshiba Satellite Pro 4600 Notebook
SAMSUNG LNS3251DC - RED POWER LIGHT IS ON BUT TV NOT POWERING UP. WHEN I PRESS THE POWER BUTTON NOTHING HAPPENS. TV HAS A DARK GLOW COMING THOUGH
Multiple causes here. The Main bd controls the Power supply. The Main bd receives the "Power on " signal from the IR sensor and the Power Button the tv. Seems that the Main bd is not sending the Power on signal to the Power supply. So the first place to start is with the Main bd. Second being the Power supply. have a trained Samsung tech troubleshoot the set.
Jul 11, 2009 | Televison & Video
Our bosch dishwasher is not working, when we press the button to turn on nothing happens, no lights, nothing, we have checked the fuse and thats ok. many thanks gail
you may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
Oct 30, 2008 | Bosch Dishwashers
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
