Plasma shows rings of contrast around highlights & shows echos of what has been on the screen which last several seconds before fading away
    Sergeant:
  • 293 Answers
This is common with plasmas actually. So long as the image fades and isn't a constant residual affect I wouldn't worry about it, but if it is constant and doesn't fade, its a sign of plasma burn out. The plasma in the tv has been active too long with one specific image or series of images.
Plasma televisions have been complained about because of this.
Posted on Sep 01, 2008
Sony tv when i turn tv on only shows vertical lines then they slowly fade away and goes black
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 14, 2017 | Sony Televison & Video
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 27, 2016 | Vizio Televison & Video
Hi, Need help with ProScan TV mo#32LB30QB.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 25, 2016 | Proscan 32LB30QD 32 in. LCD TV
What's your question?my Soyo LCD when it play it show plenty of green and shows perfect human skin coluur it some out fade
May 26, 2016 | Soyo Televison & Video
Monitor colors lack contrast
Try using a preset picture setting & then compare that to your manual setting seems like you have gone out of sync.
May 09, 2015 | Acer AL1917W LCD Monitor
How do I find the determinant of a matrix?
Here is a detailed account of how to calculate the determinant of a square matrix.
I assume you know how to define your matrix, but I will repeat it here for others who might not know. You can skip to Calculation
1.Turn Calculator ON. If there are no icons, press [MENU].
Data Entry
2.Use arrows to highlight [MAT] icon. Press [ENTER]
3.Highlight the first line where it says Mat A. Use the right arrow to enter the dimensions of Matrix A. Enter 3 and press [EXE]. The cursor moves to the second dimension. Press 3 and press [ENTER].
4. The matrix entry screen appears.
5. Enter first matrix coefficient a_11 and press [ENTER]
6. Enter a_12 and [ENTER]
Key in last coefficient a_33 and press [ENTER]
Calculation
Press [MENU] and [RUN]
Press [OPTN][F2:MAT][F3:Det] Command echoes on screen as det
Press [F1:Mat] echoes on screen as Mat; screen shows det Mat
Press [ALPHA] A The screen displays det Mat A
Press [ENTER] to calculate the determinant.
If the matrix is not square, you cannot calculate its determinant.
Jan 03, 2011 | Casio FX-9750GPlus Calculator
When i click the F2 and F3 it doesn't show MAT or Det...?
When you press the OPTN key you see Tabs at the bottom of the screen. The second one from the left should be the submenu for matrix operations.. When you press F2:MAT, the new tabs are Mat, M>L (Matrix to List), det (command to calculate the determinant etc.
Data Entry
Calculation
Dec 13, 2010 | Casio FX-9750GPlus Calculator
The screen on my Phaser 6360DN is to light to read, is there a way to adjust thee contrast?
On control panel press DOWN button to highlight "PRINTER SETUP". press OK. Press DOWN button to highlight "CONTROL PANEL SETUP" press OK. Press DOWN button to highlight "CONTROL PANEL CONTRAST" press OK then press UP or DOWN button to adjust. Repeat for "CONTROL PANEL BRIGHTNESS" if required. Press RETURN several times to go back to HOME screen
Apr 20, 2010 | Xerox Phaser 6360 Laser Printer
I am using a casio fx9750ga plus. I cannot get
I assume yoy know how to define your matrix, but I will repeat it here for others who might not know. You can skip to Calculation
Data Entry
Calculation
Hope it helps..
Oct 14, 2009 | Casio FX-9750GPlus Calculator
Horizontal flashing color stripes.1/2 second intervals on pic
Nov 07, 2017 | LG 42PG20 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
