These are old, never used, a gift from 2004. Black with orange trim. The "power" button seems always depressed, and I can't turn them off, so they kill the batteries.
Sounds like the power button rubber has degraded . please dismantle the radio and clean the button contacts with mild solvent. use nail polish remover to accitone. Don't use soapy water.
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/
There
are more than two thousand and four hundred posts. All are related to
television and other domestic electronic equipment service help.
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5
times. Led will light turns green orange with the last glow orange. (Do
not be mistaken 4x because the printer will die completely, but it is
temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... Printer is ready for use. I hope this solution will helpful for you Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful THANKS & Keep Using fixya
You can try the following
1. Turn off printer, cable power still plug in, 2. Press Resume Button don't release 3. Press Power Button don't release and than release Resume Buttons 4. Press Resume Button 6X 5. Turn off printer cable power still plug in 6. Turn on printer again, now this printer ready to use.
Or try 1. The printer is turned off and plugged the power cord. 2. Press Resume button 2 seconds then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first) 3. Then release the RESUME button, but do not release the POWER button. 4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ... 5. Release both buttons simultaneously. 6. Led will blink briefly and then will glow GREEN. 7. And the computer will detect new hardware, just ignore ... 8. Press the POWER button, then the printer will die. 9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Here's How to Reset Canon IP2770 Error 5200: 1. The printer is turned off and plugged the power cord. 2. Press Resume button 2 seconds then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first) 3. Then release the RESUME button, but do not release the POWER button. 4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ... 5. Release both buttons simultaneously. 6. Led will blink briefly and then will glow GREEN. 7. And the computer will detect new hardware, just ignore ... 8. Press the POWER button, then the printer will die. 9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
there is no reset button on lcd monitors, check power cable first, if the blue pilot led lights but no picture, you might need to bring the unit to the shop for servicing..
Hi there not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off
1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off) then turn it on again. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
No. Use a sharp pointed object to depress the metal under the missing or broken button. Remove button if necessary, or disassemble phone to get to printed circuit power button interface and press and hold it there.
