Question about Casio QV-R41 Digital Camera
SD card problem
Hello I have a Big problem I have just bought a digitalt Camera type: Qv-R41/Qv-R51 the camera runs on Memory From the camera without a card But when i Bought a SD card With 256 mb and put it in the camera it did'ent work.. I have read the manuel up to several times but it doesen't say anything about Changing cards from In built in memory to Sd card... can you help me ?
  • Anonymous Mar 24, 2014
    the green light keeps flashing and i cant power on the camera. what do i need to do?
    Master:
  • 473 Answers
Format the SD card using camera's format function. The SD card should work without a problem. BTW, what do you mean by Camera type: Qv-R41/Qv-R51? The camera should be either 41 or 51. 41 is 4MP and 51 is 5MP. Which camera do you have?
Posted on Sep 12, 2005
I have a Casio QV-R41 camera and it won't turn on
Just do the following steps which is very simple to fix your problem. Take a paper clip and if you look in the battery casing there will be three brass conductors if thats what you call them. Just bent them up to make sure that there is contact between the battery and the metal positive and negative and it will work for you.
Thank you !!
May 23, 2010 | Casio QV-R41 Digital Camera
CARD IS LOCKED
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Jan 18, 2009 | Casio QV-R41 Digital Camera
Casio Qv-r41
That's why whoever sold it to you, it's broken. Digicams are cheap enough nowadays to purchase new along with cheap large storage memory cards which comes bundled during sales.
Nov 06, 2008 | Casio QV-R40 Digital Camera
Image not visible on monitor screen
you need to install camera drivers and application software again.
Oct 22, 2008 | Casio QV-R41 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
Camera is blocking card
What does your camera do when you try to format the card? Casio only recommends using Sandisc, Toshiba and Panasonic memory cards. I dont believe that there is a firmware upgrade available for your camera that would fix what is going on. Try formatting your memory card first and hopefully that will make it able to save on your card instead of internal memory.
Jul 17, 2007 | Casio QV-R41 Digital Camera
Memory Card Locked
Do you have a computer that will read the "memoery cards"? Try reading the cards. If there is nothing on the card you still should get a message telling you the status. Check the setup of the camera. Some cameras allow you to lock the memory card from setup memu. You might also need to "format" the card before you use them.
Casio QV-R51 Battery Door
Taping the the door is about all you can do. n Battery short life may be another issue -what type of batteries are you using? Ni-Cad or NiMah are the only acceptable AA type cells[Alkaline do not have the oomph] Coming back the to door, there will not be a repair answer to this I feel- there as usually no spare parts availability. Try the Casio Tech Support- you never know your luck
Jul 03, 2007 | Casio QV-R51 Digital Camera
Casio QV-R41 Digital Camera Logo
126 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
