Question about Spectra Hello Kitty KT2028 Radio/Cassette/CD Boombox
CD lid My daughter broke the lid to the CD player and on the hinge of the lid is a lever that pushes a button that turns the player on. Where can a find a replacement lid? Thanks, MM
  • 54 Answers
I strongly suggest super glue. Just allow the hinge to move into the opened position without the lid attached and then carefully match up the broken section and allow the glue to dry. Should work just fine. A replacement would not only be nearly impossible to find but would probably cost as much in product and shipping as the unit itself is worth.
Best of luck!
Sean
Posted on Jan 14, 2009
Marantz CD Player PMD325. Cd tray won't open. Sounds like it's trying to but no motion. I have lid off but can't see what's trying to move when I push the open button.
The cd mech has to drop before the tray will open, if the belt under the front is broke you can turn the pulley wheel by hand and all will unload
Aug 22, 2014 | Audio Players & Recorders
Lid stuck
That lever is part of a hinge assembly - if the hinge has broke (and from your question it seems that it is) you have to literally de-case your laptop to remove the hinge assembly in order to replace it.
Jul 30, 2013 | Dell LATITUDE Computers & Internet
I have a dell xps M1330. My 4 year old daughter somehow managed to get 2 cds inside the cd drive and now I can't get out. Need help! Thanks.
On the front face place of your CD player, next to the button you use to eject/open the CD caddy, you should see a very small hole. Using a paperclip, insert the paperclip and gently press in the paperclip. It should release the caddy.
Apr 03, 2011 | Dell XPS M1330 Notebook
Won't spin and drain
check the switch for the lid. the machine will not spin or drain if it thinks the lid is open. use a screwdriver or ink pen to push on the little lever. the lid has a small stick of some sort sticking out. the lever is in the hole that the stick normally goes into. the lever should click each time. if not, replace it. good luck
Nov 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Turn off radioand turn on mp3 my screen is broke
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa Clip MP3 Player
Cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
Jun 13, 2009 | 2005 Nissan Altima
Kenmore Elite 24952 topload washer stops after rinse before drain
sounds like lid switch ..if switch is along right side of of opening try holding it down with pencil or other slinder object if spins ok replace switch if switch is not visible it may be under left rear hinge area ck hinge screws and tighten or try pushing hinge lever toward back slightly
Nov 26, 2008 | Kenmore Washing Machines
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Sep 04, 2008 | Whirlpool Washing Machines
Washer will not start. Water will come in. Will not spin or agitate.
new washer? whirpool is manufacturer lift lid do you hear clicking sound left corner of lid if not ck screws in hinge that corner possible lid switch is not being struck properly when lid is shut also may need to adj hinge by pushing contact lever back a little ..older unit? possible same thing different location also ck wiring to motor
May 28, 2008 | Amana Washing Machines
Spectra Hello Kitty KT2028 Radio/Cassette/CD Boombox Logo
278 people viewed this question
Top Spectra Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spectra Audio Player and Recorder Expert? Answer questions, earn points and help others
