Question about Yamaha HTR-6090 Receiver
Yamaha HTR 6090 - Remote Code, Cable Box inputs
I can't find a code that will work on my cable remote control that works the Yamaha. Also, the cable tech said something about not using the optical cable t or HDMI inputs from the cable box. We have Adelphia/Daniels in North San Diego. The sound from various HD channels will change from center speaker to fronts. This also happened on my Sony ES. Thanks, Rik
    Brigadier General:
  • 6,966 Answers
Pls post back the make and model of the cable box issued by Daniels Cablevision / Adelphia Communications as part of your subscription / package? Is it by Texas Instrument?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 01, 2008
    Master:
  • 521 Answers
The cable which you are using has to be changed as that would definately give u the problem.as it does not supports.the cable tech was right.
you can get everything what you require here.
www.radioshack.com
pls do rate the solution
thanks.
regards.
fixya expert team
    Genius:
  • 3,422 Answers
HI,
Can you tell me the make and model no. of your remote so that i can find a code for it.
HTR-6260 remote control not working
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Feb 01, 2010 | Televison & Video
How can i use the remote from my yamaha rx-v465 reveiver to control the scientific atlanta 8300hb cable box?
Yamaha remote has ability to control other devices (TV, DVD, cable box, ...) only by pre-defined set of models. Look up in your manual to the Yamaha where you will find list of manufacturers and models of devices with corresponding codes. If you can find your model there, program it into the remote. If not, you can try some of the other codes, at least program +/- and other simple functions should be quite compatible among brands.
Jan 24, 2010 | Yamaha HTR-6130 Receiver
Can't set TV code on Yamaha rav293 remote
i had the same problem with the same remote but just figured it out. on the remote, to the left of the "DOCK" button, you'll see two buttons labeled "[A]" and [B] which is what you'll use as the TV source button. press the code set button, wait for it to blink two times, then press the [A] button, and press your code. VOILA! problem solved. you could also use the [B] button, but it doesn't really matter. now the tv controls work on the remote. you may have to go through all the codes for your manufacturer but eventually it should work
Aug 08, 2009 | Yamaha HTR-6140 Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
Trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
May 24, 2009 | Yamaha HTR-6130 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Dec 28, 2008 | Yamaha HTR-6130 Receiver
UNIVERSAL REMOTE Needed for TV, Home Theatre System & DVD Player
Try maplin...there are a number of 'ONE FOR ALL' remote controls which will do your tv, radio, sky box, cable what you will have to do is program it with the codes for the particular item. the codes are usually supplied in the user manual with the remote.
Nov 28, 2008 | Televison & Video
Yamaha HTR 6040
I e-mailed Yamaha (Canada) about this problem and they said the only codes they know of are the codes that are in the owner's manual. But these codes just appear to be for the remote control that comes with the product and not for the cable remote.
So can someone out there come up with a solution?
Glenn Martin, Ontario Canada
Dec 05, 2007 | Audio Players & Recorders
Yamaha HTR-6090 Receiver Logo
238 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
