Question about Panasonic CT-36HL43 36" TV
Replace the fuse
Where do you get the fuse and how do you install it?
    Champion:
  • 252 Answers
The fuse located mostly near of the ac cord or the powewr on switch.
Posted on Sep 29, 2008
A 40 amp ignition fuse fried in my 1991 Dodge Dakota. I replaced the fuse, the starter motor and the coil. The fuse fried again. What other things need to be replaced so that my engine can start?
Pull ALL THE OTHER FUSES before installing another 40 amp and turn on the key,then install one at a time until you hit the circuit that is shorted and blowing the fuse.Now you can trace that circuit for problems.
Mar 22, 2018 | Dodge Dakota Cars & Trucks
My remote will lock and unlock my car but will not turn it on or off what is the problem?
Did it do this before ??
Well the security systems usually have an additional attachment to do this, It works basically like a relay system.. If it never did this before chances are this was never installed or never connected.
If it did perform the task before and was FACTORY INSTALLED.
There is a fuse and a relay that controls the remote start, Its located in the fuse box under the hood, There is a label on the fuse box and a diagram on the underside that will point you to the relay and fuse.
If it did perform the task before and was NOT FACTORY INSTALLED BUT CUSTOM INSTALLED.. The attachment module for this needs to be replaced or the fuse and relay for it needs to be replaced. Chances are they hid it under the dashboard. Locate and replace the fuse, and relay or module.
Dec 28, 2012 | Cars & Trucks
Fuse panel diagram
Fuses
Print
REPLACEMENT
See Figures 1, 2, 3, 4, 5, 6 and 7
Fig. Fig. 1: The power distribution box in the engine compartment contains fuses and relays
Fig. Fig. 2: Remove the cover for the interior fuse panel
Fig. Fig. 3: A fuse puller tool is located inside the fuse panel to aid in the removal of the fuses
Fig. Fig. 4: Grasp the fuses with the puller and pull straight out to remove the fuses
Fig. Fig. 5: There are generally four types of fuses used in these vehicles
Fig. Fig. 6: Fuse current rating and color code chart
Fig. Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity.
If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is easier to say than to do. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution.
Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement.
Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute.
A blown fuse can easily be checked by visual inspection or by continuity checking.
The fuse block is located on the lower left side of the instrument panel. To access the fuse panel, open the driver's side door. Pull off the fuse panel cover to get to the fuses. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
REPLACEMENT
  1. Locate the fuse for the circuit in question.
When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating.
  1. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  2. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse
Aug 10, 2012 | 2000 Pontiac Sunfire
Dashboard lights dont work
Try to adjust the dashboard dimmer switch.
or check for fuses:
CIRCUIT PROTECTION Fuses REPLACEMENT Fig. 1: The power distribution box in the engine compartment contains fuses and relays 91146p01.jpg
Fig. 2: Remove the cover from the interior fuse panel (located on the far left of the instrument panel) 91146p66.jpg
Fig. 3: A fuse puller tool is located inside the fuse panel to aid in the removal of the fuses 91146p67.jpg
Fig. 4: Grasp the fuses with the puller and pull straight out to remove the fuses 91146p68.jpg
Fig. 5: There are generally four types of fuses used in these vehicles 88256g69.gif
Fig. 6: Fuse current rating and color code chart 88256g70.gif
Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 87956094.gif
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity. If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is said than done. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution. Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement. Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute. A blown fuse can easily be checked by visual inspection or by continuity checking. The fuse block is located on the lower left side of the instrument panel. To access the fuse panel, open the driver's side door. Pull off the fuse panel cover to get to the fuses. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating.
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  3. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
prev.gif next.gif--- Or, try to look for burnt out bulbs in instrument panel.
Sep 18, 2010 | 1999 Chevrolet Malibu
I bought my car used from someone and it didnt come with the owners manuel and the cover of the fuese box is missing so i need to know which fuses r wich!! plz help
REPLACEMENT
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating. On some vehicles, you may have to remove a cover for access to the main fuse block 88256p51.jpg
    The fuse panel cover has a label with the fuse designations on it 88256p52.jpg
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse. Locate the fuse which needs to be checked . . . 88256p53.jpg
    Fig. 1: Fuse locations and component identification 88256g71.gif
    Fig. 2: After you pull the fuse from the block, check the element 88006p42.jpg
    Fig. 3: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 88006g76.gif
Jul 14, 2010 | 1996 Chevrolet Corsica
How do i replace a 120 amp fuse step by step on a toyota avalon?
There are several fuse blocks. They are located in the engine compartment, behind the right side kick panel, under the instrument panel or behind the left side kick panel.
REPLACEMENT
If any light or electrical component in the vehicle does not work, its fuse may be blown. To determine the fuse that is the source of the problem, look on the lid of the fuse box as it will give the name and the circuit serviced by each fuse. To inspect a suspected blown fuse, pull the fuse straight out with the pull-out tool and look at the fuse carefully. If the thin wire that bridges the fuse terminals is broken, the fuse is bad and must be replaced. On a good fuse, the wire will be intact.
Sometimes it is difficult to make an accurate determination. If this is the case, try replacing the fuse with one that you know is good. If the fuse blows repeatedly, then this suggests that a short circuit lies somewhere in the electrical system and you should have the system checked.
Fig. Once the cover is removed from the fuse box, you can identify each fuse and relay
Fig. All circuit breakers and fuses pull out quick easily
When installing a new fuse, use one with the same amperage rating as the one being replaced. To install the a new fuse, first turn off all the electrical components and the ignition switch. Always use the fuse pull-out tool and install the fuse straight. Twisting of the fuse could cause the terminals to separate too much which may result in a bad connection. It may be a good idea to purchase some extra fuses and put them in the box in case of an emergency.
Fig. Relays can be removed by pulling them from the block
I hope helps with this (remember rated this help) Good luck.
Dec 28, 2009 | 1999 Toyota Avalon
Trying to replace/install fuses for my 1996 Saturn sw1. Schematic not user friendly at all. Not detailed enough
n the car is a fuse box onthe driver side. but as you open the door all the way to the door hinges you willsee a fuse box it is cliped to the side of the dashboard
Nov 04, 2008 | 1993 Saturn SW1
Brake Light Fuse
You have a short in the lighting system. Try removing both brake bulbs and with a new fuse installed.. does it still blow the fuse? If not, then install one bulb at a time and repeat the test.. You probably have a short in or around the bulb socket.. Hope this helps
Sep 18, 2008 | 1997 Honda Civic
Windows wont work
Are there any blown fuses? If a fuse is to be replaced, be sure to use a new fuse of the same capacity. Always determine why the fuse blew first and completely eliminate the problem before installing a new fuse. Never use a fuse of higher capacity than specified.53df58d.gif 1. Fuse blown due to over-current. Prior to replacing the fuse with a new one, check the circuit for a short and the related parts for abnormal conditions. Only after the correction of a short or replacement of abnormal parts should a fuse with the same ampere rating be installed. c015b83.gif
Jun 02, 2008 | 2001 Hyundai Elantra
Panasonic CT-36HL43 36" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
