Question about Garden
Blades will not ingage
Pull the switch up to engage blades and nothing happens. belt is ok. john deere L120
  • 2 more comments
  • Anonymous May 15, 2009
    took deck off to clean. put it back on and worked for about 3 minutes and now blades will not engage
  • vegaslady314 May 23, 2009
    JD Model L120
    4 yrs old - only 140 hrs on it. Numerous starting problems. Have replaced gas cap twice - common problem they say. Transm. has been replaced as has battery & fuel pump.
    Worked for about 1 hr. then blades stopped.
    Blades will not engage. No blockage - blade will move manually, deck is clean. (Stopped while running). Went to JD service to pick up new electrical piece. . ...did not fix problem. Can only think now that there is short in wiring.
    Mower has been down most of ownership time. A definite lemon or pooooooor quality mower. Problems began occurring first week of use. Mower is clean, well-serviced. Has been garbage - a total waste of money (purchase plus repairs). Would not recommend this model to anyone. JD service in my area is of no help.
    Does anyone have a solution?
  • Anonymous Mar 24, 2014
    nothing happens when the PTO is engaged
  • Anonymous Mar 27, 2014
    cannot engage the blade gears to make them rotate
  • 18 Answers
Is it electronic engage or manually?
Posted on Sep 03, 2008
Manually
Posted on Oct 17, 2008
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
May 04, 2017 | John Deere Garden
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
John Deere L110 Mower wont engage
Depending on which type of PTO you have the problem could be simple to diagnose... if you have an electric PTO, you may be dealing with a bad switch... if electric, you should have good tension on the belt at all times. If it is a lever that you push/pull to engage the blades, then it would seem that the tensioner pulley is not applying the required tension on the belt... could be a broken spring or a worn/slipping belt (not enough tension)... hope that gives you somewhere to look into...
May 21, 2013 | John Deere Garden
John Deere L120 Lawn tractor, Mower will not engage.
could be the switch that engages it also check to make sure that the blade is not stuck by something do this with mower shut off
Oct 20, 2012 | Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
your electric pto clutch switch is bad replace it
Nov 14, 2008 | Garden
Garden Logo
739 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
