Broken LCD Do most LCD TVS break down in less than two years. Holw long can a good one last. would you buy a LCD or a plasma. What what you buy. Thanks
  • 6,487 Answers
Plasma television is on for 8 hours a day, its half-life would be about 9 years - or, if on 4 hours a day, the half-life would be about 18 years.
Keep in mind that a standard television loses about 30% of its brightness after about 20,000 hours. Since this process is very gradual, the consumer isn't aware of this effect, except for the need to periodically adjust the brightness and contrast controls to compensate.
Although the performance of individual Plasma TVs can vary, overall, as a product class, a Plasma television can deliver many years of acceptable viewing.
Hope that helps........
Posted on Sep 01, 2008
Bottom 8 inches of screen is black rest of screen works grate what is the problem this is an lg 60pg60f tv
Replace the TV. It is a plasma television and the bottom 8" has burned out. For future reference, DON'T buy a plasma TV. This is a very well-known issue with plasma TVs in general. Go with LCD or LED. These are more resilient to hot places, direct exposure to sunlight( though it is not recommended to expose it for any real length of time as, this will bleach out the lights and\or the screen and you will be buying yet another TV), and are less expensive than plasma.
I have worked on TVs for years so, please stay away from plasma.
Here is a website you might find helpful in explaining the functionality of the different types of TVs and what to look for before buying your next TV. PlasmaFix com Plasma Repair Answers
Aug 15, 2017 | LG Televison & Video
Tip
Plasma -vs- LCD? Pros and Cons
If you're looking into a new TV purchase these days, you have only a few options… Plasma and LCD are major hitters. What follows is this professional’s opinion; you must ultimately do the research yourself.
Plasma TVs
Pros: Exceptional color reproduction. Our eyes have become accustom to viewing TVs with Phosphorus displays. As with TVs of old, Plasma TVs also use Phosphorus to create the beautiful colors our eyes crave. The viewing angle (side to side) and refresh rate (rate at which the image is refreshed) of a Plasma product shines above most other product types. Plasma TVs also have a glass protection screen in front of the panel which can help protect the panel from impact. Prices have fallen recently and have made the Plasma TV a very affordable purchase.
Cons: Energy usage. Using a Plasma TV has been likened to 'leaving the refrigerator door open'. Reliability and longevity are also a factor to consider. Over time, the Plasma panel becomes more sensitive; “Sparkles” or misfiring pixels are common. The Plasma uses many high power components; which, due to failure, have given it a less than reliable stigma. Image retention and image burn are quick to occur. Realistically, 5-7 years of life.
LCD TVs
Pros: Light weight and bright picture. Color reproduction has improved by leaps and bounds over the recent years. Some products available do rival the Plasma products in picture quality and reproduction. Cost cuts have also brought the LCD into the price range of many. Energy usage is typically less than that of the Plasma. Image retention is not a major concern for this product. Less parts than a Plasma = Less failure. LCD panel life is estimated to be about 10 years.
Cons: LCD panels use back-lighting systems. Because the 'color' of the light does not change, the color reproduction of the LCD product is not as natural to the eye as the Plasma product.
LCD-LED TVs
(Same as LCD TV, with the following exceptions)
Pros: LED back-lighting produces a more Plasma like color response.
Cons: Panel life is about 70% that of the standard LCD products.
on Apr 12, 2010 | Televison & Video
Life expectancy of television
Depending on the type of TV, the longevity can be affected significantly. If your TV is a plasma model, they run very hot and the plasma only lasts about 4-5 years. That is why plasma is no longer being made by any of the major manufacturers. It was state of the art when it came out, but now LED TVs are the standard. They use much less energy, run a lot cooler and last much longer.
Longevity really depends upon the technology used, not always who made it.
May 03, 2017 | Sony BRAVIA Televison & Video
When powering up the monitor comes on,then flickers a little,then display goes black.can the e233h monitor be reset?
Probably not. This is most likely either a backlight going out, or an inverter board going bad, or other internal component (costs $100+ to replace by a professional). Not worth it to fix in most cases, unless you have an extended warranty, or a local repair shop with really good rates.
However, you can try another monitor cord (between monitor and computer; not likely to be the problem, but rarely can help). Flat screen (monitors/TVs/laptops) generally last 5+ years with average use, but I've seen them fail within 2 years (especially on laptop computers). In general, if you got 3 to 5 years out of a monitor, you did ok.
PS: If buying a new LCD monitor or TV, look for one that says "LED" on the box. (LCD monitors traditionally had a few fluorescent bulbs inside as "backlights", but newer LCD monitors/TVs have hundreds of tiny LED lights inside, which last longer, use slightly less electricity, and give more even lighting on the screen edges).
Dec 02, 2013 | eMachines E233H Bd 23" Widescreen Lcd
Best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Oct 28, 2011 | Televison & Video
DURING TRANSPORATATION MODULE OF THE PLASMA T.V. BROKEN. I WANT TO REPLACE THE SAME. PLEASE GIVE ME ADDRESSE WHERE I CAN BUY THE SAME. FURTHER ALSO INFORM THE PRICE OF THE SAME
Tries websites Like Amazon.com,Ebay.com to buy the same LG Plasma tv u have.In search...just put in LG Plasma tv 42" the model nunber...U will get a list of tvs dealers saling tv for ur LG plasma tv models and many more.The prices might be up or down depend on the tvs market.
Nov 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Can you tell me what a Panasonic Viera Model TH-42PD25 would be worth today? I'm thinking of buying one second hand and aren't sure what I should pay. Thanks!
Hi.
Second hand price is difficult to say, probably about $500. If the unit is in good shape it does not go down too much.
New RRP is over $1000, offers however start at about US$600 (about £400 in UK). Probably you can find a little cheper in Ebay.
Here a link: Panasonic Viera TH-42PZ80U
I suggest not buying a second hand plasma. Plasma TVs have a couple of weakness points, and often break down after few years usage. If you buy a second hand you do not have any info on its usage, and you may find yourself in need of changing a sustain board within the year.
Oct 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My Samsung lcd tv screen has a crack under the panel. Is this repaired ? What are the approx charges. TV is 4 year old
Not repairable,beacuse replacing the LCD or Plasma screen are consider the same as a new tv.The screen panels are limited produced by the tvs industries and are 90% important to the tvs.Will not find it any where to buy the screen panels except by the tvs industries themselves.That what they charge for a new screen panels the same as a new tv,so the screen panels are broken,crack or damage.The tv only can be salvage for electronic boards for parts,that it.Not worth as a whole tv anymore.
Jun 21, 2010 | Samsung LN-R408D 40 in. LCD HDTV
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
Broken LCD
well dont trash it.. it will cost you more to fix it than it will take to buy a new one what you can do is search for another broke one with a good LCD screen or most tv repair shops will buy it from you for parts on the last LCD tv i sold to a repair shop for a 26" thay gave me $100.00 dont know how thay are in your area but it is worth looking into.
Nov 16, 2008 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
