Question about Microsoft Xbox 360 Console
Xbox 360 60Hz over-satured and displaced colors (normal TV, non HD).
Games that are 60Hz only for X360 play fine on my TV except for the fact that everything gets a bit oversharpened and some colors are misplaced. For instance while playing Doax2 the blue of the water will show through the skin color of the character models.. Is there a fix for this?
Friendly greetings.
Make sure you have the right colors wires in the right ports
Posted on Oct 12, 2008
Screen is black and white but plays fine
try a different tv set as it could be setting on you tv which is causing the black and white.
Oct 30, 2009 | Microsoft Xbox 360 Console
Color is off on my xbox 360.has a green tint.any idea how to fix this?
You have two options, first: change the display settings on your tv so that the xbox screen looks normal. Or change the color display settings in the console settings menu. Play around with the saturation until it looks right to you. Also, make sure to keep electronics off the top of your tv. I've noticed that this can sometime change the color of the screen in certain places. Hope this helps.
Jul 14, 2009 | Nintendo Wii Console
Unreadable text
I do not believe there is a solution. I had the same setup and could not read the text. I tried everything and eventually got rid of the 360 because without an HD TV, I could not read anything.
May 31, 2009 | Microsoft Xbox 360 Console
Color distoration, then the game froze and now video wont work
It could be as simple as the video cables. Get another set of cables and try it. You can get them pretty cheap on auction sites. IF that dont work then I would say your headed for the 3 red lights or no video problem. If thats the case then check with ms and see if your still under warranty. If not we can help. We are registered repair service on this site. thanks
Jan 29, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Green Tint On Xbox Monopoly Game
have you tested with another game?
maybe you are running a EURO game...the colors go´s normal...try a usa version...
Dec 05, 2008 | Microsoft Xbox 360 Console
Cant play games on Xbox 360 live
imma suspect its overheating. beings the fact youve experienced the red ring of death in the past. its either overheating or the hard disk is going bad. unless your using a memory unit. then id point the finger at overheating. the x360 is basically a computer. and when the cpu and gpu overheat or experience harsh temperatures they tend to run sluggish and their performance goes down the **** till they cool down or overheat to the point that the system locks up and crashes/hangs. if you can post more info as much detailed as you can i may be able to more help ya!
Nov 12, 2008 | Microsoft Xbox 360 Console
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Xbox 360 graphics
Its likely u just have the sockets for ur av cable plugged in incorrectly, this happened to me, the screen was pink though, i fixed it soon enough
Dec 01, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
96 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
