Question about Microsoft Xbox 360 Controller
Wireless controller position
Not sure how to ask... i set up one wireless controller, and then another so i had player one and two. i then tried to set up the player two controller as the player one, and it did not work. i turned off both controllers and the remotes, and reconnected the second attempting to make it primary but it again only recognized it as player two. how do i make the player two wireless remote be recognized as the primary one? (its brand new, other one is older)
Try this:
Under heading "How can I change the screen positions for my wireless controllers?"
http://www.xbox.com/en-US/support/systemuse/xbox360/resources/supportfaq.htm
To reset the screen configuration for an Xbox 360 Wireless Controller:
  1. Turn off your Xbox 360 console and any connected Xbox 360 wireless controllers.
    (To turn off your wireless controller, power down the system and wait for the lights around the controller's Xbox Guide button to disappear.)
  2. Manually turn on your Xbox 360—don't use your controller's Xbox Guide button.
  3. Press the connect button on the front of your console. This is the small button just to the right of (or below, if your console is on its side) the port for Memory Unit B. The lights around the console's power button will flash as the console searches for a wireless controller.
  4. Press and hold the Xbox Guide button to turn on the wireless controller that you want to assign to slot one.
  5. Once the controller is on and the lights are still circling the power button on the console, press your controller's connect button, located just to the right of the charge port.
    When the lights on your controller stop spinning, the wireless controller is configured to slot one and the upper-left quadrant light will glow.
  6. Select the controller you want in slot two and repeat steps 4 and 5. You can configure up to four wireless controllers.
Posted on Sep 27, 2008
O14 code
Normally, this happens if you have entered an incorrect wireless password or the signal strength of the network is not that strong. I suggest that you try to relocate the Roku player and make sure to position it facing the router's location.
Double check your router's wireless password.
Jan 03, 2014 | Roku LT
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
Wireless setup
IN ORDER TO SET UP A WIRELESS INTERNET CONNECTION, FIRST MAKE SURE YOUR COMPUTER HAS A WIRELES CARD IN IT, SECOND YOU NEED A WIRELESS MODEM,
Mar 29, 2012 | Sharp Bd-hp80u Blu-Ray Player
Where can I find a controller (model E-R0002) for a Logitech wireless drum kit for a Ps3. They are not available from logitech any more? Thanks
I'm not to sure about what you're asking here but no controller is needed for the wireless drum set. There is already buttons to control the PS3 on the drum set for use while in menus.
Mar 03, 2011 | Logitech Wireless Drum Controller for...
I have a linksysWRT120N AND AM TRYING to connect it to my roku player but it is asking me for security code
if you are referring to a wireless connection, most likely it is the wireless security configuration. Access 192.168.1.1 using internet explorer and access the wireless tab. Make sure that your player has the same wireless configuration to make it work. After configuring sometimes after saving the settings you may need to restart the devices.
May 02, 2010 | Linksys WRT160N Wireless Router
How to turn on the wireless capability by using a combination of function keys. Have re-installed the driver and turned the switch to on position but windows could not detect.
Make sure Windows is set to manage your wireless. Control Panel --> Administrative Tools --> Services
Make sure "Wireless Zero Configuration" is started, and is set to Automatically Start.
Good luck.
Mar 08, 2010 | Sony VAIO VGN-N250E/B Notebook
Tries to connect sees wireless network and continues to try and connect but never will
when you try to connect to the wireless network does it ask for the wireless password ?
If your wireless network is secured then it should ask you for the password of the network.
You can try to remove the network from the preferred network list.
Also check the wireless settings of the router.
Make sure that you have all the correct wireless settings.
To check the wireless settings of the router , you will need to open the router set up page.
Click here for more information about the routers and wireless networks
Jan 31, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
Tried connecting controller with xbox on and buttons doesnt work
If you power up a new controller and the Ring of Light lights just keep cycling around in a circle without settling on a position, this means that the game console does not recognize that controller.
This can happen with a new controller or when replacing batteries.
To sync it up with the XBox 360, you need to first turn on your game machine,
then turn on the wireless controller (push the Xbox button and hold it until it lights up),
then press the little connect button on the game console (round button to the right of the two memory slots on the front of the machine),
then press the connect button on the rear of the wireless controller in between the left and right buttons that you normally push with your index fingers (above and to the right of the battery release button).
The Ring of Light will cycle on the controller and then it will be assigned a position by the Xbox and stay lit. To turn a controller off or disconnect it, press and hold the Xbox button in the middle for a second or two until the light goes off - if you are in the middle of a game it will ask you if you want to turn off just the controller or the console as well. When the console powers down, all wireless controllers are automatically turned off.
If this does not work, attempt to connect with a different controller to make sure that the controller you are trying to use is not defective.
Hope this helps!
Apr 06, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
Feb 10, 2009 | Microsoft Xbox 360 Controller
Step 11 and 12...
I would guess you didn't do it in the correct order.
Are you 100% positive th  Ethernet cables are in the right ports?
Check the one that goes from the modem, to the router.
If that doesn't help, would you let me remotely control your PC and see what it looks like?
Oct 17, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Microsoft Xbox 360 Controller Logo
1,169 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
