Question about Microwave Ovens
Oven doesn't heat
This is a 2002 Maytag electric microwave oven, model #MM5186AA. It no longer heats. The touch pad no longer beeps. After I put in the time and hit start the turn table turns and it sounds as if it is heating but the timer won't count down and the food doesn't get warm. When I set the clock it will not keep time. It will stay at the time which was set. I have checked the child safety lock and it is off. Had a repairman out who did all that I tried and then said I probably had a bad circuit board. He reccomended that I buy a new oven. What do you think?
  • Microwave Ovens Master
  • 9,098 Answers
Did you or the the repair man do a hard reset?
Thefirst thing I would suggest is a hard reset. Unplug the unit for aminute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Plus, I'm assuming your model is actually MMV5186AA, right?
If it turns out to be a bad board, we actually repair those for customers nationwide for $39.95 in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 01, 2008
  • William Miller
    William Miller Sep 02, 2008
    Then it may be a bad board, and we repair these for customers nationwide for $39.95 in most cases.
    William E. Miller
    prototech@usa.net
Why is the outside panel hot to the touch?
Many factors at play here. Are you cooking on the range? Are you using the microwave? Is the light on?
There is very little current going to the touchpad and if there were a short in it the touch pad would not work. It is just heat from another source. Don't worry about it.
Dec 13, 2014 | Maytag Appliances Over-the-Range Microwave...
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
Microwave is locked
Try this:
To cancel the child lock.
1. Touch and hold ENTER/START pad more than 4 seconds.
LOCKED will disappear and you hear two beeps.
May 07, 2010 | Maytag MMV4205 Microwave Oven
Microwave will not heat up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghkd
Feb 25, 2010 | Maytag MMV4205 Microwave Oven
Microwave no longer heats, makes more noise than it did when it was heating. Microwave is a Maytag, model # MMV4205BAW. Thanks.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Nov 27, 2009 | Maytag Appliances Over-the-Range Microwave...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Microwave Ovens Logo
102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
