Repair of room air conditioner /window unit
When power is connected to my Maytag air conditioner' model # M6Y18F7A-E, the only thing that happens is that i get the code "EE" on the led screen.The power button doesn"t work at all. Could it be that I need a new panel with a new board ?
    Genius:
  • 2,035 Answers
EE room thermister error, EEprom error you need to change the control panel of the unit of the AC Please use this link to get the part:
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=129294&typeName=air%20conditioner
Good luck...
Posted on Sep 01, 2008
    Master:
  • 521 Answers
ON THE FIRST PAGE were new procedures for resetting the error code. Unplug unit, clean filter, HOLD DOWN power button and CONTINUE HOLDING while plugging unit back in. Unit will beep. Unplug again, plug back in and resume normal operation.
    Master:
  • 848 Answers
You need to check the main breakers in the breaker panel......
Fan squeals when the unit is first turned on. can the fan be oiled?
YES BUT IT REQUIRES REMOVING THE TOP COVER OF THE UNIT .. USE A ZOOM SPOUT OILER. THE WORK THE BEST ! ADD OIL AT THE SHAFT NEXT TO BOTH SIDES OF MOTOR
Jul 28, 2011 | Maytag M6Y18F7A Air Conditioner
My 18000 btu Maytag window air conditioner does not cool. The compressor kicks on in an attempt to cool but no cool air comes out.
Hello my name is Heath it will be my pleasure to assist you. One thing I can suggest is try plugging the air conditioner into a surge protector.
Jul 01, 2010 | Maytag M6Y18F7A Air Conditioner
When running it squeels
sounds like the bearings are going out on the blower motor...........needs replacement.................
Jun 26, 2010 | Maytag M6Y18F7A Air Conditioner
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
I have a Maytag M6Y18F7A Air Conditioner window unit & am having problems w/ the thermostatic control not dropping below 75o. Originally, the unit switched to 67o which wasn't really a concern, but 75o...
This sounds like the control board has malfunctioned. You might have to have it replaced. When you have it on, does the unit switch off at 75o or does it continue to run? Also check the temp of the air leaving the unit, it needs to be below 55o's.
Mar 30, 2009 | Maytag M6Y18F7A Air Conditioner
I am trying to find a motor for M6Y18F7A
Hi Sal,
You didn't mention which motor you're looking for, so here is the condenser motor and her is the dual shaft motor. These links have part numbers so you can shop around for the best prices.
Hope this helps!
SG
Mar 26, 2009 | Maytag M6Y18F7A Air Conditioner
No POWER WHEN TURNED
lol not good , these unit are not meant tobe repaired make sure the outlet is not 220 check breaker or try other outlet.
May 16, 2008 | Maytag M6Y18F7A Air Conditioner
Heating & Cooling Logo
436 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
