Question about SanDisk Sansa m240 MP3 Player
Need To Clear My MP3
I Got My Sansa Sandisk m240 From My Step-Brother And When I Go To Clear The Library, It Doesn't Show Up On My Computer.And I Don't Know How To Delete Songs On The MP3 Player Manually. I Need Help Please! Any And All Help Is Much Appreciated.
  • Anonymous Sep 08, 2008
    it plays file that was already deleted
    Problem Solver:
  • 20 Answers
Actually i had somthing liek that ahppen to me mine played 3 songs that had been deleted i still have not figured it out so i bought a Zune ^_^
but fullmetal you go to your computer there is this thing called
removable disk (:E) and you will have a couple folders in there you want to click music and it shoudl show all of the songs that are in there, then you just delete the songs
~Temp
Posted on Sep 09, 2008
Delete files or clear music files off disk to rebuild music library.
plug it into your cpu then go to my computer select your mp3 player and open it by clicking on it then go into your music files and delete what you do not want on it it is a very easy drag and drop style mp3 player
Nov 18, 2009 | SanDisk Sansa m240 MP3 Player
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
My m240
Before you can create a playlist and transfer (or synchronize) them to your Sansa
player, you need to show Windows Media Player where your songs are located.
Adding Music Files to Library…
To add music files to WMP 11’s library, follow these steps:
1. Click the arrow below the Library tab.
Loading Content 13
2. Make sure Music is selected then click Add to Library.
3. In Add to Library dialog box, click one of the following options then click OK.
- My personal folders:
Use this option to monitor the digital media files stored in your personal
Music folder as well as any files stored in the public Music folders that
everyone who uses your computer has access to.
- My folders and those of others that I can access:
Music folder, the files stored in the public Music folders, as well as the files
stored in the personal Music that belong to other users on your computer.
Oct 25, 2008 | SanDisk Sansa m240 MP3 Player
Synching songs to Sansa m240
YOU MIGHT NOT HAVE SYNCED RIGHT....YOU MIGHT NEED TO DRAG AND DROP YOUR FILES OR CONSIDER GETTING A SANDISK E200 OR A CX00 VERSION MP3 THEY ARE MUCH EASIER TO WORK WITH
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
SAn Disk Sansa mod m240
in the settings menu on the mp3 player you will see a usb setting (hopefully) you have to change the settings in there and it should work hopefully
Jan 30, 2008 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
Problem with my MP3 player...
I am having the same issue. I loaded my M240 with music, then umpluged it from the USB cable. It didn't do the "building library" thing like it always does, and now when i turn it on it just loops from the "Sandisk" startup screen to the "Sansa initiallizing" screen. The same as you, when i connect it to the pc it isn't even recongnized and the player loops the "initiallizing" screen again. I put a request in to Sandisk last night, so i might have a solution for us later today.
Jun 15, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
Freezing
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line. We do apologize for any kind inconvenience this issue is causing you. For verification, does your computer have Windows XP as its operating system? This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution. Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding. If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer. Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer. To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data. Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears. After formatting the Sansa m240, please do try your Sansa m240. If applicable, please go the link below to download the firmware update for your Sansa m240. The link is: http://www.sandisk.com/Retail/Default.aspx?CatID=1326 or http://www.sandisk.com/Retail/Default.aspx?CatID=1376 If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer. NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
