Hello.. I have a asus motherboard m8L9ga and need to know the pins for the speakers and everything else. the pins are not marked on the board. the board I am taking out is marked so I know what the wires are but don't know what the pins on the board are. thanks larry
First select your windows. Next select the manual folder and click on global for download. Please unzip the file. You need adobe reader to read the content.
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sadael.
Yes some-times the case/computer chassis does not have an internal BIOS/CMOS beep code speaker built in.
So what you will need to do is go to your local computer store and purchase a mainboard beep code speaker. You may even find it online at your favorite computer store.
The modern speaker is very small compared to the older mainboard beep code speakers.
Your computer will continue to work without the speaker, the beep code speaker is there to help diagnose/troubleshoot problems when they occur.
Hello, You will remove the CMOS battery and wait for 5 minutes . Hope it will solve. If the problem is same please change or clean the RAM with eraser and install it again. If the problem is same please , http://www.techspot.com/review/129-asus-p6t-deluxe/If the mobo is in warranty should change .If period expire Now you will create a identity mark on BIOS chip and ,you should remove resoiulder the BIOS chip from *********** board .and install it again tightly.
If all the procedure will fail think your mobo should change as new. Hope this helps.
hello there here is a weblink that will get you going in the right direction i know you have the acer motherboard but the pins will generally be the same ok? here is a pdf downloadable flile that will help you. best regards michael
[PDF]A7V133-VM3051k - Adobe PDF - View as htmlSupports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System PowerLED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Open your case and find a cable that comes from your internal speaker and connect it to pins on motherboard marked pc speaker or int.speaker or speaker
Go to http://support.asus.com/download/download.aspx?SLanguage=en-us and from there search for your motherboard. I have just installed the same motherboard(second hand) in my computer and didn't have a cd. I checked on the site and found everything I needed there.
