Question about Irons
Steam iron I have a Black & Decker steam iron. I use filtered water when filling it. Often while I'm ironing the water seems to leak out of the bottom plate and the ironing board pad is soaked. I have even been burned when lifting the iron and having hot water drip on my feet. Is it time for a new iron or is there a solution?
  • garfield788 Oct 26, 2008
    I have exactly the same problem. Iron is 9 months old.
  • Anonymous Mar 29, 2014
    how do I lift the water fill cover on my iron. it wont lift up
  • 30 Answers
Time for a new iron, safety first , you will be surprised at what you can get on sale these days
Posted on Sep 03, 2008
The iron heats well and I put the water in, but even when set above the steam icon, pushing the white steam button does nothing. No steam no spritz. When I opened the water chamber to let the water out, I...
Before you go through the process of taking it apart, buy some clr or a similar lime and rust removal product and fill the iron with that, let it sit a while and then dump it out and fill it with water a few times. Often if tap water is used, internal deposits will form and block off the passages, same as what happens in your car radiator over time.Most steam irons work better if you use distilled water in them as there are no dissolved minerals in that. Most replacement parts cost nearly as much as the iron itself and it's generally not cost effective to repair them.
Jun 23, 2011 | Black & Decker Gizmo C520 Iron
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
Jul 18, 2010 | Black & Decker D2020 Iron
I have bought a swan s15040n steam generator iron and it does turn on but I can't get to generate any steam. I have tried holding the steam button down for 20 seconds ( and more) but still nothing. Any...
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
Jul 13, 2009 | Black & Decker Steam Generator SG200 Iron
I have a Black and Decker First Impressions (about 2 yrs old). When on steam it always spits out large puddles of water on the clothes as I'm ironing. It seems to come from the top or bottom part of the...
It's a possibility that you iron steam making elements are caked with lime and possibly the steam holes as well.
Purchase some "Lime Away" and dilute it 50/50 and pour it into your steam iron (drain all the old water out first and leave the iron unpluged) let sit for an hour or so and drain out, fill it again with clear water shake and drain out do this a couple of time then turn on the steam and see if it works properly, use the first time on an old towel to be sure all the chemical has been rinced out. Good Luck.
Feb 28, 2009 | Black & Decker D2030 Iron
I cant figure out how to put the water INTO the iron
Looking at the front of the iron there is a spray nozzle and right above it there is a spot that opens to fill with water.
Feb 23, 2009 | Black & Decker Steam Xpress AS250 Iron...
Water leaks out of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 23, 2008 | Black & Decker Steam Xpress AS250 Iron...
New iron, stopped heating and leaked water
heatman101
May 22, 2008 | Black & Decker D2030 Iron
Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Feb 12, 2008 | Irons
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Irons Logo
215 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
