Question about Archos 604 Digital Media Player
Archos 604 hard drive problem
Mine dropped, and now the hard drive is disconnected. Can you describe how the hd connects with the ribbon piece, or point me to somewhere i might see instructions for this. Much thanks, as I've enjoyed this for several years and not quite ready to part as it ahs been working fine.
    Problem Solver:
  • 4 Answers
There is a nice pictorial dissasembly at this site:
http://archos.grimchuck.com/disassemble-tuto/EN/index.html
Posted on Feb 25, 2009
Archos 604 (not wi-fi) does not recognize the hard disk in any mode
Posted on Aug 15, 2009
How do i downloan from archos604 to my computer
Connect it to the USB port of the laptiop with the cable supplie with the 604. A popup will appear on the Archos screen - select the firts option. The Archos will then be visible to your laptop as an external hard drive. You can then drag files across from the Archos
May 11, 2010 | Archos 604 Digital Media Player
HOW CAN I DOWNLOAD MUSIC VIDEO AND VIDEO TO MY ARCHOS 604
screw that software. When you plug in the archos the archos asks what your doing with it. Say Hard drive mode and then you can drag and drop and file you want onto it.
Its pretty simple put movies in the movies folder and mp3s int he music folder lol.
Jan 03, 2010 | Archos 604 Digital Media Player
When switched on goes to a HDD Recovery option but when options tried a Media Failed message is received and 604 returns to the original screen
I have the same problem and I do not know how to fix it. The problem with mine is that I have replace the hard drive with a new one so it does not have the original files. Does it connect through the USB connection and does the computer detect it?
May 20, 2009 | Archos 604 Digital Media Player
ARCHOS 604 WIFI PROBLEM AFTER FIRMWARE UPDATE
if you wouldnt mind losing data then i suppose you could format it and get rid of the firmware update and the put all your stuff back on. only a suggestion.
Oct 27, 2008 | Archos 604 WiFi Digital Media Player
604 - how does ribbon connect on the unit side
The ribbon cable should slide into the connector but be careful since that latch can break.
Mine broke.
Sep 05, 2008 | Archos 604 Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Archos 404 recovery code 2
i have an archos 404 the problem is that my archos show me the recovery code 4 to repair or format the disk so when ever i repair and format the disk the problem is solved. so please help me regarding this.
Mar 01, 2008 | Archos 404 Digital Media Player
Downlaoding movies
Once you have downloaded the file to your PC simply connect your archos to your pc using USB cable provided, select PC hard drive mode, and simply copy or drag and drop from one destination to the other. Your Archos usually appears as J:Archos604WiFi if you have a built in card reader if not it may appear as an earlier letter in the alphabet.
Dec 27, 2007 | Archos 604 WiFi Digital Media Player
Code 2
hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Dec 20, 2007 | Archos 604 WiFi Digital Media Player
Recovery (code 2)
I got the same message when I took out the hard drive. I'm sure this will void any warrant, but maybe you should open it up and make sure the hard drive ribbon is secure.
Nov 12, 2007 | Archos 604 Digital Media Player
Archos 604 Digital Media Player Logo
1,089 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
