Logik mobile tv tuner
I've got a Logik DVD player with a related mobile tv tuner. when I connect the tv tuner to the DVD player, I can see the images but cannot hear the audio. What should I do?
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
SOURCE: ht-ddw790
Be sure audio cords from tv are connected to tv inputs on back of receiver...TURN VOLUME UP...GREAT SOUND!!!
Posted on Mar 31, 2008
SOURCE: Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Posted on Aug 18, 2008
SOURCE: Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Posted on May 08, 2009
  • 46 Answers
SOURCE: My television does not have
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Posted on Mar 08, 2011
Connecting a dvd player to a logik tv
see the diagram attached: God bless you
Jul 21, 2012 | Televison & Video
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Can i connect a tv tuner to my lmd-4702ru dvd
if theres an video input you can connect it purchase an digital box it can recognized almost all channel that available in your cable and antenna.
Sep 24, 2009 | Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Mar 12, 2009 | RCA DRC-285 DVD Player
Logik Tv
sounds like the tuner is shot the board can probably be replaced fairly cheap from E Bay.
Jan 17, 2009 | Star Logic 17" LCD Monitor
New flatscreen/remote not working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If your Remote is ok, then the problem with the Remote sensor or related components of the device.
Oct 16, 2008 | RCA DIRECTV Satellite Remote Control
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Oct 01, 2008 | Toshiba 32D46 32" TV
Samsung DVD V9700
Double check the cables. if it has a tuner, use that
Nov 25, 2007 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
