Question about Craftsman 17029 Wet/Dry Vacuum
Troubleshooting I am trying to reverse the flow to "**** up" dust from drywalling. How do I do that?
    Scholar:
  • 99 Answers
Plug the hose into the other side of the unit. One end pushes air and the other side draws in the air. Now drywall dust will clog your filter quickly. Clean the filter often. Do not clean dust without the filter. It will get all over everything!
Posted on Sep 01, 2008
I am vacuuming spackle dust from sanding walls and my electrolux canister continues to open. What should I do?
Fine dust from sparkle will clog a bag or filter very quickly even though the bag is not full or even close to full. The air can't pass through the bag so it is popping the door open. Drywall dust can ruin a vacuum motor very quickly. I use a shop vac style vacuum with a cartridge filter that still clogged up after just a few minutes of vacuuming the dust but I can take the filter outside and hit it against something and use a small soft brush to clean it.
Jan 28, 2018 | Electrolux Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Having lots of drywall dust, vacuum cleaner is connected and hose is having suction but sander is kicking dust all over the place. Can you help .
Wet some old bed sheets and lay it on the floor where you are sanding.Sand by hand.Using a power sander will not only damage the wall;but will also damage both the vac and sander
Jan 21, 2018 | Vacuums
How do i make sand on little alchemy
Rainbows don't really trap as much in the water as the salesman says. That's why they don't want you to suck up drywall dust. To the extent that dust floats in the air, it also stays just as suspended in the bubbles as they go through the tank. When the bubbles pop at the surface of the water in the tank, much of the airborne dust isn't trapped and gets sucked through the motor. The idea of sucking gunpowder through a Rainbow sounds interesting. There's sparks flying around the commutator in that motor and you could possibly have dust going through. Id like to watch you suck up gunpowder.....from a distance.
Dec 06, 2014 | Rainbow Vacuums
Rainbow e series shooting out dust
Did you place water in the water pan? Are you picking up drywall dust, baby powder, wood ash, etc.? This type of material is difficult to be trapped by water.
RainVac
www.rainvac.com
800-523-0510
Mar 31, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Was vacuuming sheetrock (drywall) dust and the water boiled over and shut off the vacuum. Any hope for it?
The water boiling could indicate the motor getting too hot. Remove the seperator and clean it with a wire brush. Then wipe out the inside to get the dust out. Let it sit a while then try it. Chris
Feb 07, 2011 | Rainbow Vacuums
Bag full signal shows when a bag is still on its
This is often caused by fine dust such as drywall dust or an internal filter behind the bag being clogged. Look for blockage in the bag comaprtment
Sep 06, 2009 | Vacuums
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Kenmore progressive canister hose cleaning
remove hose take it outside and flush with TSP solution then rinse with water (garden hose) let dry. spackle dust and drywall dust are water soluble and will not hurt your grass.
Nov 07, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Drywall Dust Damaging to Vacuum?
it shouldnt hurt it as long as you keep the vacuum clean after use when you leave the dust sit in on it it hardens but as soon as done vacuum the motor and blow it out with compressed air this shall give you a longer life
May 16, 2008 | Fein 9-77-25 Turbo III Bagged Canister...
Craftsman 17029 Wet/Dry Vacuum Logo
111 people viewed this question
Top Craftsman Vacuums Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
