Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
TV panasonic TH42pd50u
TV try to start.Vsus 180v and Ve156v appear for 1sec then TV shut doun.Lamp blinks 7 times.Please help.
  • 61 Answers
It clould be either problem with Driver boards or Y-sus or powersupply itself
Isolate SU and SD board first and power up,then see What is happening.Then Isolate SD then SU.
Good luck
Posted on Oct 10, 2008
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
TH42PZ85U Panasonic that will turn on for a couple of seconds, not even long enough for picture, then it shuts off. Red power light blinks 2 times with about 3 seconds in between the 2 blinks. I am...
1. Reseating the connector P25 may solve the problem. If it does not.
2.Right before the unit shuts down, check the VSUS voltage at connector P2 of the power supply. If VSUS voltage measures zero volt, disconnect the connector P2 and SS11. Check the VSUS level at socket P2. If it is still low, replace the P board.
3. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
4. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The screen is totally blank when the tv is switched on. Also, a red light at the front of the tv blinks 7 times before pausing for a few seconds and then repeats. I have checked all connections and tried...
Missing Vsus. Abnormality of the scan circuit output, the 15V_F, the scn_pro, and Vscn circuit. Loose or open Connection between the SC board and the SM board (SC41, SC42, SC46). Open or loose connection between connectors SC2/P2 Wrong diagnostic by the A board Defective panel
Feb 19, 2011 | Panasonic TC-P42G15 Plasma TV
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
My set just shut off and is now blinking 10 times.
What can possibly cause 10 blinks
A.Missing/Shorted F_15V
B.Shorted Vsus
C.Missing/Shorted SUB5V, SUB9V, BT30V.
D.IC1100, IC9003, IC9004
E.Unplugged SC20, SC2
F.Possibly SU and SD boards
Information from Panasonic.
May 18, 2010 | Panasonic TC P42S1 42 in. Plasma HDTV
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My panasonic Th42pd50U shuts off then blinds 8 times in a cycle. it is 5 years old...Can this be fixed.
Blinking usually indicates a voltage problem, caused either by a sustain board or power supply and sometimes both.
This would take a workshop repair and would probably be beyond economical repair if parts are available.
Some people have been able to change the boards but I cannot advise about the voltage adjusts on fit that would fix if you managed to get the part cheap enough.
Jul 06, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic yh42pa20 shut down issue
there are a number of parts that may cause your problem power supply, z or y sustain boards, drive boards or panel. needs a qualified servicer to check out.
Jan 23, 2009 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
