Friedrich window air conditioner
Compressor does not go on-----display screen reads E7---what does symbol indicate?
  • Anonymous Sep 01, 2008
    my central york air conditioner stopped working. It was on auto then I swithced to fan but no sound came .I turned it off for now.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
The inside unit has the control power which tells everything what to do.Check power to the unit,(breaker), check to see if the fan door is on tight--- then, lAST but not least, check the fuse on the circuit board! Thank-you-very-much!
Posted on Sep 01, 2008
How do i recharge freon for me Friedrich KM18J30A-3 window unit?
only a certified HVAC technician has the license to carry and use the freon used in home A/C units. it's not like the car units we can do ourselves.
Jul 14, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
Compressor wont start
Check power to compressor relay and start capacitor before condemning compressor. Also check it's not low on gas.
Apr 18, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
Digital keypad does not respond on Friedrich through the wall AC ("Weathermaster). If I hold down the "cool" button for several seconds, I get E-2 display.
First, check the reset switch on the power cord. If after holding it in for 2 seconds, the unit does not reset itself, it means that you will need a service call. In addition, I have looked over the Owner"s Manual for you model, as well as the Service Manual and no where can I find a reference to an E-2 display on your LED screen. If resetting the unit does not solve the problem. Contact Fredrich's Customer Support Dept (800) 541-6645.
Jul 06, 2011 | Friedrich CP08N10 Thru-Wall/Window Air...
Our Friedrich Floating Air system keeps throwing the breaker. Worked fine for 5 years, now can't get it to stay on.
Check compressor is taking correct amps, if high amps due to capacitor weak, replace it. And also check for any short circuit in wiring.That is also the reason for breaker tripping.
Finally,
Remove power. Check compressor terminals after removing wiring, When your ohms read something between any terminal and grounding, it's understood that compressor grounded. Replace it.
If windings reading should be : SR should read the total of CS and CR (C=COMMON, S=STARTING,R=RUNNING). If the total is higher or lower, the compressor winding is weak. That time it takes higher amps and breaker get tripped.
Hope helpful?
Jan 21, 2011 | Friedrich M18CF Split System Air...
The compressor doesn't turn on; it just displays a 12. Sometimes it goes on a while later.
That sounds like the overload is on the way out. Remove the cover atop the compressor and check the overload for signs of distress. Make sure the capacitor is not swollen looking or leaking, another sign of a capacitor going out. 69d27fe.jpgd4a019c.jpg
Jul 16, 2010 | Friedrich QuietMaster Electronic SS12J30D...
The compressor only stays on for a few minutes/window unit
I would check capacitor to compressor to make sure it is ok...also check voltage being supplied to unit
May 10, 2010 | Friedrich CP12C10 Wall/Window Air...
Friedrich a/c zq10 thermostat won't kick in
likely is the thermostat or could be the compressor going out on over load compressor runs blows cold air trips out on the over load fan will stay running jumper out the thermostat see if it stays running.like1/2 hr. if it does replace the thermostat not hard to change if you can find one.Tom
Jun 18, 2009 | Friedrich ZStar ZQ10A Air Conditioner
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
