Question about Centrios EDW8020 DVD Recorder
RECORDS BUT WITH DISTORTION
The player will record but the picture is distorted. Is there a fix for this?
My picture rolls and won't stop. I unpluged it several try's........
What will fix it........
Posted on Nov 10, 2008
Sony pvw2800p-when done with the recording & then playback at different machine,there seem some picture distorted(at the top frame)like recording in a low head quality,but already changed a new...
distortions are present on the same machine?
Need to check the squareness of recorded frequency mod packages, using a test tape CR2-1B. Distortion at the top of the frame it misses the heads on track while entering. Adjust S-reel achieve squareness packages.
Feb 23, 2011 | Sony PVW-2800 VCR
TV plays fine when dvd recorder is off. As soon as you turn on recorder the picture gets snowy. It doesn't matter whether it is on video 1 or on the channel setting. I have changed all the cables, still...
It seems that you are keeping the recorder close to the TV set resulting distortion in the picture due to power supply hum,check by keeping it away from set if no change than check the reason of hum received from power supply of recorder by replacing electrolytic capacitors for leakage or proper shielding of power supply in side the recorder.
Jan 22, 2011 | Panasonic DMR-ES40V DVD-Video Recorder
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
My camera will play back images but distorts new images
Hi!
It's faulty CCD (imager). Ask Sony if they change them for free there.
Tom
Jul 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
Small picture from player (not wide screen)
Set the all settings to wide, not auto as if the player is set to 4:3 format then this sends a signal to the tv telling it so.Go into the setup menu and choose picture format set to 16:9 or wide. Set the tv to auto and this will keep all picture inputs to origional format. I.E. if it was recorded in 16:9 it will play in 16:9. You could set the tv to 16:9 but it will distort the picture on 4:3 recordings.
May 31, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Pictures distorted play/record mode
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Mar 30, 2008 | Philips HDRW720 DVD Recorder
PD-6030 MP3 Voice recording distortion
MyMusix's PD-6030:
Manual can be found at www.mymusix.com
EQ setting
Select from "Normal, Rock, Jazz, Pop, Classic, Bass" .
You can also select "Exit" to keep the original settings.
Menu Tree Diagram is on p.29
For "password" question - there is no password, the lock on the player has simply been engaged - slide it to the unlocked position. See manual for details.
-Tha Mp3 Doctor
Nov 05, 2007 | MyMusix PD-6030 MP3 Player
Centrios EDW8020 DVD Recorder Logo
158 people viewed this question
Top Centrios Televison & Video Experts
Henry  Thomas
Henry Thomas
Ron Oblinsky
Level 1 Expert
timtation123
Are you a Centrios Televison and Video Expert? Answer questions, earn points and help others
