Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Regarding thermal sensor
Can i ask where it is located ?how to install? and where i can find one?
  • Sony Master
  • 8,617 Answers
They are usually located on our near the lamp housing. Vancebaldwin should have one. They have a scew that secures them and then just unplug the wires
Posted on Sep 01, 2008
Mo steam or hot water
Check that the temperature sensor is working correctly. If it is covered in scale or otherwise faulty it may be causing the machine to leave the heat on longer than it should. If you have a multi meter use it to monitor the resistance through the ntc (providing the machine uses this kind of temperature sensor) as the temperature rises. It should be fairly linear. Try cleaning the sensor or replacing it. Also check to see if the heat is turned off when the water reaches the correct temperature.
Dec 13, 2014 | DeLonghi Coffee Makers & Espresso Machines
Error 4
Unfortunately the error message 5 indicates that the thermal block and/or thermal sensor and possibly a control board need to be tested, and likely one or more, possibly all, replaced. My recommendation is to send it to Capresso ask what it will cost first. M
Aug 11, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
1998 nissan maxima runs hot, replaced the thermostat and at times gauge still register hot, what else could cause this?
Its possible that your problem also stay in the Engine Coolant Temperature (ECT) sensor resistance changes in response to engine coolant temperature.
Keep in mindthat the sensor resistance decreases as coolant temperature increases. This provides a reference signal, which indicates engine coolant temperature, to the ECM.
Fig.: Compare the sensor readings with these values
Fig.: Location of the thermal sending unit (A) next to the coolant temperature sensor (B)
Keep us updated.
Oct 12, 2011 | 1998 Nissan Maxima
F3 CODE ON kENMORE ELITE MODEL 7904637940 PLEASE HELP
Hi There
I have found the code that you are looking for and i hope this helps you.Let me know how it goes.
F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuseThank you for writing to fix ya
Best Regards Richard
Mar 21, 2010 | Kitchen Ranges
Location fuses Whirpool duet dryer
The thermal fuse is located on the blower housing outlet to the left of the thermistor. For electric dryers, the thermal cut-off and high-limit thermostat are located on the heater housing. For gas dryers, the high-limit thermostat and the flame sensor are located on the burner.
Disconnect the dryer from the power outlet and turn-off the gas supply for gas dryers.
Remove the two screws at the bottom of the toe panel securing it to the cabinet. Pull the toe panel down and off the cabinet.
Check the continuity of the thermal fuse with an ohmmeter set to X1. The ohmmeter should read zero ohms. Replace both the thermal fuse (part #3392519) and the thermistor (part #8577274) if the resistance reads open or infinite. Remove the securing screws and install the replacement part.
Do the same with the thermal cut-off. Replace both the thermal cut-off (part #279973) and the high-limit thermostat (part #3391914) if the resistance reads open or infinite. Remove the securing screws and install the replacement part.
The high-limit thermostat is located next to the heater terminal block and next to it is the thermal cut-off.
Slide the toe panel in place up and into the cabinet and secure it with the screws.
Note: Disconnect the wires from the terminals of the component before performing the continuity test.
Feb 22, 2010 | Washing Machines
Can the thermal sensor be replaced by the tv owner without much trouble
Yes, it is located on the back of the lamp housing, you take the screws out of the fan duct and move it out of the way then there is a screw at the bottom of the thermal fuse on the back of the lamp housing unscrew it and pull the thermal fuse up and it will come out install a new one then put it all back together.
Nov 09, 2009 | Mitsubishi WD-65732 65" Projection HDTV
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
anand_anj2005@hotmail.com
Apr 12, 2009 | Computers & Internet
Slow write speed
Had the same problem with my WD2500KS-00MJB0. It also has the (widely reported) defect where the thermal sensor is not reporting correctly (ie 40C when it's just been powered on, and should be reading approx 20C!).
My suspicion is that this line of WD2500KS models has a defective thermal sensor, and after a period of time the thermal sensor fails. When this happens, I suspect that the drive firmware tries to lower the temperature by reducing write speed.
My drive was out of warranty, so I used the 'Customer Loyalty Upgrade' discount on the WD Warranty Check site to get a new 500G drive. I still have the old drive, and some technical knowledge, so I'll see if there's a hardware hack to disable the thermal sensor.
Otherwise, go to the WD site's Warranty Check page, and get yourself a (heavily discounted) Customer Loyalty replacement.
Mar 22, 2008 | Western Digital Caviar WD2500JB Special...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
