Delete all messages and call logs.......if still problem persists then probably there are some malware occupying your memory which creap in if u use internet on ur phone......solution is - factory restore ur phone after backing up only important data.....if this does not work then hard reset ur phone.....press vol. up, camera and power button together for a few seconds.......download/boot mode will appear......press menu or vol. down button and scroll down to CFT calliberation ...select using menu button......phone will restart....this should solve ur peoblem..
I solved the problem! Description of the problem: my touchscreen went crazy (it selected random thins, especially in the bottom region of the screen) quite often and every time i had to lock/unlock the phone in order to fix it... but after 30 sec the problem went back! Solution: remove the back lid cover, the battery and the sd card; unscrew the 5 screws and remove the second plastic lid; behind the battery slot you'll see three metal flap: when I opened my phone one of them wasn't in contact with the card! I fixed it and I cleaned these three contact with alcohol! Now my Wildfire S works fine!
Go to Settings->Applications->Manage applications. At the Downloaded tab, tap on the application of choice, and tap "Move to SD card" button under the Storage section.
Please note that not all applications can be moved (disabled "Move to SD card" button) due to some Android system requirements. If an application is already moved, the button will now be named "Move to phone". You can also select the "On SD card" tab to view apps already moved.
Also, there is a free app by Sam Lu available at the Android Market.
You can Format your SD card .Just insert your SD card to Card Reader in your PC.Dont forget to move Lock button in to Unlock Position.Then make a Fat file type Format...
If you connect the phone to your computer and select 'mount as disk drive' when prompted, open up the removeable drive (your SD card) and put the music file you want to use into the 'music' file on the SD card.
Unplug the USB cable and go to 'music' in your phone. Select the song you want to use and then press menu, this will give yuo the option to select it as your default ringtone.
