Question about Microwave Ovens
Microwave display window shows locked!!!!
Small grease fire on range oven cause microwave over the range to evidently overheat. Open the door and the light is on but push other buttons and nothing happens. Smart Sensor window display shows LOCKED. Is there a reset? Could not locate manual online. Please help with my problem or any ideas on how to solve problem.
Kenmore 721 - 62643200 1000 watt manufactured November 2002
Thanks.
  • Jeff L G Sep 02, 2008
    I was able to locate a manual online thanks to the help of customer service rep at the 1-800 # for Sears. I perused the manual and found that the only possible solution could be the child lock had been activated and the microwave overheated. I pressed and held the start/lock button for 4 seconds and it unlocked the microwave.
    Thanks for your suggestion, because I was really getting a little nervous. Hope this will help someone else in the future.
    Thanks again.
  • Microwave Ovens Master
  • 9,086 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
There may be grease or soot on the control panel causing a lockup, and it may need circuit board cleaning / repair or a new keypad.
Posted on Sep 01, 2008
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
My Frigidaire ffmv162lw Microwave just shows "0:05" on the display and no buttons work.
You have a shorting membrane keypad. And you are correct - if and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking, especially if it's doing this!
The details of my answer assume that your model number (from the tag on the microwave, not the manual) is FFMV162LWA (white). If not, please let me know.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can order part number 5304477374 from the Sears Parts Direct Web site for $98.65 (prices subject to change).
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then detach the keypad connector as shown in the photo below, and then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Reassembly is the reverse of disassembly.
Feb 16, 2014 | Frigidaire FFMV162LW Microwave Oven
What caused this to catch on fire?
its the grease that has got into it replace it and allways keep it clean
Dec 06, 2011 | Frigidaire Microwave Ovens
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
GE Microwave oven turns on briefly when door is opened.
good question .. but your ok the door inter locks may be waring and may need adjustment. . the mag will take about 20 to 20 sec to fire up after the power is on . so you are safe . not a uncommon event with ovens. / ****
Jan 09, 2010 | GE JVM1440 Microwave Oven
Microwave door locked
open the cover of the oven you can see see the lock near the key pad. Press the lock the door will open. You can adjust the alignment by refixinfg the screws.
May 12, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
F-6 showed up on my microwave window
self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "?" is displayed...
F6 ?Microwave Relay Failure: Check the microwave relay.
Jan 26, 2009 | Whirlpool MH7140XF Microwave Oven
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
145 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
