Question about Canon EOS-AE-1 35mm SLR Camera
Shutter Speed I bought my Canon AE-1 a couple of years ago and used to be able to set and use the shutter speed without any problems. I can still change the setting of the shutter speed when the camera is set to manual but the shutter still fires at a quicker speed than wanted....even when it is set to B.
    Problem Solver:
  • 7 Answers
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Posted on Apr 07, 2009
Black line from bottom to half way up camera which gets higher as i increase shutter speed
Chances are you're using too high a shutter speed. Here's a link to understanding how that works. Good luck!
High Speed Sync Flash
Jan 09, 2013 | Canon EOS-AE-1 35mm SLR Camera
How to set shutter speed in fuji fine pix S2940
That depends on the exposure mode. In any of the automatic point&shoot modes you have no control over the shutter speed, the camera sets what it thinks is the proper shutter speed. In the P (Program AE) mode you can adjust the shutter speed by pressing the +/- button. In the S (Shutter Priority) and M (Manual) modes you control the shutter speed by pressing the +/- button and then using the cursor-up/down buttons.
Apr 25, 2012 | FUJIFILM S2940 Digital Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
Aperture setting and shutter speed together?
Yes it does. Check your manual. If you don't have a manual you can get a pdf download from canon. This link should get you there. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=214&modelid=9429#DownloadDetailAct
Sep 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Shutter speed lagging.
There is a common problem that most A series Canon develop with age. There is a small set of gears that govern the speed of the mirror rising. One gear is brass and becomes dry, (lack of lubrication). You should have the camera serviced by a repair person or there are kits available to DIY. You can find the kits on eBay
Sep 16, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon 20D err 99 and shutter going off continuously
its not the battery
its the exposure of the shutter speed of the camera
it might need to be set manually. set it to 2.8 or 4.5 speed
i had the same problem when i bought my sigma 20mm-80mm lens.
the lens wasnt talking to the camera properly, it didnt know what it was aying about exposure speed rate.
put the camera in AV mode and set the speed rate.
the lens might be compatible with your camera even though it is a canon, or it could be defective
return and replace
Apr 21, 2008 | Canon EOS 20Da Digital Camera
Shutter stuck on Canon AE 1
Just now saw your problem.....I can repair this for you. No it's not "overwound" you possible have some small piece of plastic that caused your second curtain to get hung up and thus jam the entire camera. I have probably repaired 500 AE-1's with the same problem. Art www.flcamerarepair.com
Nov 22, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon ae-1
To open the back pull on the rewind knob ( pulling up ) until back opens. Check that your 6 volt battery is ok ( ae -1 has an electronic shutter so will not work without a battery ): battery situated on the left hand side of the camera ( if it is facing you ) underneath small flip up door ( lock is at the bottom on the left of the small door ) . Check the battery by pressing the shutter release gently and seeing if your light meter needle moves. No movement ? replace battery. You have two modes for taking pictures : auto which is actually AV ( aperture priority) or full manual : both are set by moving the shutter speed dial on the top right hand side ( underneath film winding lever ).
Sep 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Shutter Only Fires at 60
Remove transport/winding lever and loosen the retaining ring underneeth. Gently lift shutter speed dial and reseat it. Tighten the retaining ring and reattach winding lever. ( the shutter speed dial is not engaging the mechanism inside the camera and you need to establish proper connection ).
Aug 24, 2007 | Canon EOS-AE-1 35mm SLR Camera
AE-1 Didn't Take Pics
Possibly the film did not go through the camera. If it did, the problem may be the 2nd(or closing)curtain magnet on the bottom of the camera. When the magnet is working the closing curtain of the shutter is held back 1 to 1000 miliseconds-depending on the shutter speed selected by you. 1ms=1/1000 sec. 1000ms=1 sec. You can tell by 1. removing the lens 2.setting the shutter speed to the "B" setting 3. opening the film door and looking through the camera 4. releasing or firing the camera and keeping pressure on the release button. If the magnet is working, the shutter will stay open as long as the release button is kept pressed down. The closing curtain will close as soon as the release button is released. When the magnet fails, both curtains travel across the film plane together and no exposure is made. Sometimes there is corrosion on the magnet where the wires connect. Sometimes there is some foreign substance or object that interferes with the face of the metal unit that attaches to the magnet when the camera is wound. Sometimes the magnet just fails and needs to be replaced. If the magnet checks out OK the problem may be in the circuits that control the release of the magnet. If this is the problem, the camera needs to be looked at by a competent repair shop. Just so you know, new parts are getting hard to come by, but there are tons of used cameras around that parts can taken from. Hope this helps.
Jun 24, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
384 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
