Question about Ryobi Cultivator
Engine starting brand new out of box cultivator engine does not start, it tries to turn over first pull but thats it. what can be adjusted ?
  • 1 more comment
  • skzm Mar 11, 2009
    Almost started the first pull. After that it would not turn over. Anyone have any ideas? Brand new out of the box, followed the instructions to a T.
  • ramjet50 Mar 23, 2009
    Same problem.  Right out of the box, carefully follow all instructions but will not start.  Does not even try to fire.  Plug looks okay, fuel lines look okay.  Currently large pointy door stop.  Any words of wisdom welcome.
  • vnufall May 12, 2009
    can't start the ryobi cultivator, starts and cuts off
3 Suggested Answers
  • 112 Answers
SOURCE: ryobi 410r cultivator needs intital carb adjust
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Posted on Jul 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Bolens BL410 cultivator that stops running
Hi and welcome to Fixya. The symptoms your describing are typical of what happens when the engine experiences fuel starvation.
It can be caused by a clogged fuel filter screen located at inside the attachment point of the fuel line manifold on the carb. Turn off the fuel and remove the mounting bolt for the fuel mainfold. Very carefully remove the plastic screen inside the manifold and clean off the debris that has built up on the screen.
If the screen was visibly clogged you probably have solved your problem. Just make sure you re-install the screen when re-connecting the fuel line manifold.
If the screen was not clogged then check your fuel lines for cracks. Air being introduced into the system will cause the same symptoms you describe.
If the problem persists then there is the possiblility that the needle and seat are partially blocked inside the carb itself on the bottom of the carb body after you remove the bowl. (Usually not the problem) However the bolt that holds the bowl on has 1 or 2 holes in it that can also clog and they must be clear.
And finally there is a BRASS jet that unscrews with a screwdriver in the bottom of the long draft tube (way below the throttle slider / needle) that gets clogged. Unscrew the brass jet and force air from the threaded end to clear the orifice.
By this time you probably figured out the float comes off with the bowl. note which side is UP! Also DO NOT adjust the float level it is preset. u|Unless you bent the float control arms it does not need adjusting.
Turn on the fuel... and start the unit after re-assy and it should run just fine. You should be tilling real soon!
Posted on Jan 29, 2010
Testimonial: "Good detailed feedback. I have been looking for air leaks in the fuel lines, but did not realize there was fuel filter for this engine. Thanks"
How how to adjust the screws on the carburetor of the yard machine yard cultivator 31 cc
Hi Christi:
This is a "standard approach" that i've used for various small engines for a long time. It may not be factory specs, but it's worked for me.
- First, gently turn both screws in (clockwise) until they just touch the seat. BE GENTLE as you don't want to damage the needle or seat.
- Second, back out both screws 2 turns. This is a "guess" start point.
- Third, start using normal procedure.
- Once the choke can be opened, with the saw at an idle, adjust the slow speed screw until the saw runs at its slowest smooth idle.
- Finally, increase the engine speed and adjust the high speed screw.
Try turning it clockwise.
- If RPM increases, continue until it starts to decrease, then back off 1/4 to 1/2 turn.
- If RPM dropped or engine stalled, back off 1/2 turn and try again.
Hope this helps.
Aug 31, 2015 | Garden
Why is the rope starter not engaging the motor how do i fix it or do i need to return it
Try pulling the rope slowly until the starter engages the flywheel (you should feel when it engages) then give a good pull to start the engine. Don't give the rope a quick hard pull in one motion. You will probably need to do this three or four times before the engine starts. Of course push the primer button the number of times called for in your engine instructions before trying to start the engine. If you still don't think the starter is engaging the flywheel if would take it back where you bought it if it's new.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Engine has no power
-Possibly air fuel mixture is not correct.
-Make sure after start move the choke lever to full open. let it warm up for 2-3 minutes before pull full throttle. If still no power then adjust the air mixture in or out. Just little and try, you'll see the difference.
If better then adjust more, but if more worse than turn other direction.
Good luck
Mai
Jun 16, 2014 | Honda Garden
I just put a new carbuator on my troy tiller pony it is 23 years old ,still hard to start and will no idle very well.
There are many problems with small engines that can make them hard to start. The carburetor is one of them. Make certain that you have adjusted the new carburetor correctly. A good place to start is 1 1/2 to 2 turns counterclockwise from the closed position on the main fuel adjustment needle. Adjust in or out to best performance when engine is running. Some carburetors also have a fuel adjustment needle for the idle mixture. Start off with 1 to 1/2 turns counterclockwise from closed and adjust in or out to best idle performance. Other potential problems include bad spark plug, ignition system (points and condenser in your unit?) and a defective intake and/or exhaust valve.
Oct 29, 2013 | Troy-Bilt Garden
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
Tiller won't start. brand new
did you mix proper gas and oil. check or replace plug and check for spark
Apr 21, 2013 | Ardisam Inc Earthquake Mini Cultivator
Brand new tiller tines will not turn scv43
look to see if the drive belt fell out of place during shipping
Jun 06, 2012 | southland Garden Cultivator Tiller S-cv-43...
Engine surges
sounds like a carb problem if new bring it back to the store
May 05, 2012 | Husqvarna DRT900 960930011 17 Rear Tine...
Tiller won't start.
I recently had the same issue with a tiller that hadn't been started in over 8 years. Turns out that old gas had left a varnish coating in the carburator keeping the gas from feeding. Rebuilt the carburator with new float, needle valves and bowl, new Welsh plug. Fresh gas and two pulls later it went to churning. Took a short time to adjust the two needle valves for idle and full throttle and we went a-tilling.
Apr 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Ryobi Cultivator Logo
248 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
