Question about Medion 9653 Digital Camera
Locked memory card
I was using camara and all of a sudden it says card locked , how can i unlock it
  • issy1157 Sep 01, 2008
    memory card in camara medion has locked can it be unlocked
  • 4 Answers
If your camera uses SD cards, as most likely is the case. There is a little plastic switch on the SD card, you must have switched it. Switch it back.
It is a primitive write protect, it only works if the device checks if it has been switched, the camera will check this.
Posted on Sep 30, 2008
How to unlock "card lock" on a Exilim EX-V7 camara
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 07, 2013 | Casio Exilim EX-S500 Digital Camera
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
Why my camara reads card protected.,,,i pearches a memory card and the camara doent work
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Nov 26, 2010 | Polaroid a550 Digital Camera
Protec. Escr. ¿qué significa esto?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 28, 2010 | Olympus FE-240 Digital Camera
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
The camara said camara memory locked i need to know how i can unlocked
Did you using SD card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
Jul 09, 2009 | Canon PowerShot A460 Digital Camera
Camara lock
Take out the memory card there is a little lock on the side of it. move the lock over and this should fix your issue. hope this helps
Apr 01, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Medion 9653 Digital Camera Logo
80 people viewed this question
Top Medion Cameras Experts
Are you a Medion Camera Expert? Answer questions, earn points and help others
